12-04-2010 08:04 PM - edited 03-21-2019 03:20 AM
I am cutting over a customer to a UC560. Inbound dialing seems to be working fine but outbound dialing is not. According to the service provider they are requiring the calling party number be sent to complete a call. The system is currently sending calling party name which the carrier is rejecting. I am not aware of any way to remove the calling party name from within cca. How can I remove it from CLI?
12-06-2010 06:26 AM
Under the Outgoing dial-peer for the call you can put the following command in to strip Calling Name:
Dial-peer voice 1 voip
clid strip name
If you are not sure which dial-peer is matching for the outbound call, running "debug voip ccapi inout" will tell you the exact outgoing dial-peer that the call is using.
Adam Compton
12-09-2010 08:21 PM
Thank you. That did the trick!
