Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
195
Beginner
Outbound Digita Translation on UC560
We have SIP trunks on a UC560 and we need to edit local number i.e. 123456 to insert the area code before sending out as the SIP provider needs the area code.
Is this straight forward?
Everyone's tags (1)
1 REPLY 1
Hello,This can be done but
This can be done but not through CCA. CLI only. You will need to modify your local outgoing dial-peer to match a translation-profile with a translation-rule that will insert the area code.
If you use CCA for your all other configuration changes, you won't be able to make changes to your outgoing dial plan. CCA will overwrite it.
Chris
