OUTGOING CALL ROUTING
cruz.javier
I have UC560 with E1,
if im try to make a call for default it try FXO trunks. I want to use My E1
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-national-plus
description **CCA*Mexico*Long Distance Mobile**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9045..........
forward-digits all
no sip-register
voice-port 0/3/0:1
voice-port 0/1/0
trunk-group ALL_FXO 64
cptone MX
connection plar opx 30099
description Configured by CCA 4 FXO-0/1/0-OP
caller-id enable
voice-port 0/1/1
cptone MX
description Configured by CCA 4 FXO-0/1/1-OP
caller-id enable
voice-port 0/1/2
cptone MX
description Configured by CCA 4 FXO-0/1/2-OP
caller-id enable
voice-port 0/1/3
cptone MX
description Configured by CCA 4 FXO-0/1/3-OP
caller-id enable
controller E1 0/3/0
framing NO-CRC4
line-termination 75-ohm
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
  country telmex
  category 2
  answer-signal group-b 1
  caller-digits 4
  groupa-callerid-end
how can i config alla the outbound calls need to be router to the E1???
David Trad
Hi Cruz,
In CCA did you configure your E-1 correctly?
If you have no need for the FXO ports then in CCA you can disable them so that way all your calls go directly to the E-1 service.
Are you getting any errors when you try to make a call now? Do you have some ISDN debug captures for us to look at?
Cheers,
David Trad.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
7 Replies 7
David Trad
Hi Cruz,
Cheers,
David Trad.
I did the configurarion in the CLI, becasu for Mexico i dont hace the options in the CCA for R2 Modified, i used this configuration for the E1 port:
controller E1 0/3/0
framing NO-CRC4
cas-custom 1
  country telmex
  category 2
  caller-digits 4
  group-callerid-end
I contracted with the ISP the E1 complete 31 channels.
When i made a try to call on the IP phone it take to long to get a tone and the cut off the signal, i call 9 and 7 digits (93149693).
i have this in the default sh run command
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice-port 0/3/0:1
voice-port 0/1/0
cptone MX
caller-id enable
voice-port 0/1/1
cptone MX
caller-id enable
voice-port 0/1/2
cptone MX
caller-id enable
voice-port 0/1/3
cptone MX
caller-id enable
dial-peer voice 59 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*Mexico*International Calls**
preference 5
destination-pattern 900T
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
description **CCA*Mexico*LADA**
preference 5
destination-pattern 901..........
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*Mexico*Emergency**
preference 5
destination-pattern 9060
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 060
forward-digits all
no sip-register
dial-peer voice 69 pots
trunkgroup ALL_FXO
corlist outgoing call-local-plus
description **CCA*Mexico*Local Mobile Numbers**
preference 5
destination-pattern 9044..........
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup ALL_FXO
description **CCA*Mexico*Local Calls - 7, 8 or 10 digits depending on loca**
preference 5
destination-pattern 9[1-9]T
forward-digits all
no sip-register
The issue here is in the dial peer is directed to trunkgroup ALL_FXO, and this trunkgroup is in the FXO trunks.
I dont know how can i tell to the UC to use the E1 port instead of FXO.
I need help for this.
Hi Cruz,
Can you please put your configuration onto a text file, and then upload it up too hear so I can see it please.
Please also make sure to remove any of the sensative information such as username and passwords and WAN ip addresses from the configuration, or just replace the characters with an "X" so that way you do not reveal any sensative information.
Cheers,
David Trad.
There it is at my dropbox in text file, im researchin if i found some on the google..
http://dl.dropbox.com/u/37621655/run-uc560-latelec
Hi Cruz,
Please give the following a try... I hope I havent missed anything as I am at work right now and wasnt able to spend much time on it, but this is all I could come up with right now without focusing on the issue...
In theory you should be able to just copy and paste this as I have tried to steer away from anything that is the same on yoru configuration, however before you apply this configuration please make a backup of your current one.
trunk group ALL_T1E1
translation-profile outgoing PROFILE_ALL_T1E1
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile nondialable
translate called 1000
voice translation-rule 4
rule 15 /^...$/ //
voice translation-rule 1000
rule 1 /.*/ //
dial-peer voice 6 pots
description tcatch all dial peer for BRI/PRIv
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
trunkgroup ALL_T1E1
preference 5
forward-digits all
no sip-register
trunkgroup ALL_T1E1
preference 5
forward-digits all
no sip-register
trunkgroup ALL_T1E1
preference 5
forward-digits all
no sip-register
trunkgroup ALL_T1E1
preference 5
forward-digits all
no sip-register
trunkgroup ALL_T1E1
preference 5
forward-digits all
no sip-register
trunkgroup ALL_T1E1
preference 5
forward-digits all
no sip-register
trunkgroup ALL_T1E1
preference 5
forward-digits all
no sip-register
Good luck and I hope this resolves your issues for you.
Cheers,
David Trad.
I will try tomorrow in the morning in the office.
I have one question where did you tell to use the E1 port, as i see here you create a trunk group for ALL_T1E1 but this name is customized right?
i does not mean the UC will know wich port is for outgoing calls.
For example this
voice-port 0/3/0:1
voice-port 0/1/0
cptone MX
caller-id enable
Voice port 0/1/0 is the FXO and member of trunk group ALL_FXO
And i suppones my E1 is the Voice-Port 0/3/0:1
What is the meaning of 0:1, channel 1? or it is the complete channel the first  longest iddle?
How it works?
Hi Cruz,
I am not sure why yours is that, I mostly see the E1's here in Australia as "voice-port 0/2/0:15"
I couldn't tell you how the E1 should be configured in your country sadly
If you are not sure if the ISDN is working (E1) then make sure you do a "debug isdn q931" and advise of the results.
Cheers,
David Trad.
