05-01-2009 02:03 AM - last edited on 03-25-2019 10:36 PM by ciscomoderator
I've setup a SIP trunk on the SPA9000, but where can I define the outgoing caller id for the phones??? Every phone (or ext) shows the registered username of the sip trunk (btw, it's the customers primary phone number).
Eivind
05-01-2009 02:39 PM
Hi Eivind,
This is highly dependant on your ITSP.
In my case, any changes to my outbound caller id that my ITSP results in outbound calls failing with "Forbidden".
With the above in mind, here's how you can modify your outbound caller id:
Refer to the SPA9000 Administration Guide's "Managing Caller ID Settings for Outgoing Calls" and the "Supporting Direct Inward Dialing to Phone Extensions" sections available at https://www.myciscocommunity.com/docs/DOC-1750
In summary here's what you do:
Assume you currently have a contact list of "41,cfwd=vm441" and want to ext41 to display a name of "Test Caller ID" with a number of nnnxxxyyyy
Edit the SPA9000's web-ui:
> Voice > Line N > Subscriber Information >
Display Name: Test Caller ID
Contact List: nnnxxxyyyy:-41,cfwd=vm441
Again, I stress that this information will in the outbound SIP local user information, but your ITSP may, (probably will) ignore your configuration and present what they choose to present on your behalf.
Patrick
05-01-2009 03:37 PM
Hi Patrick,
I want to have several extensions with the correct number translation for outgoing calls, is that possible or am I only able to show one PSTN number for outgoing calls??? There is no limitation at the ITSP regarding manipulation of numbers.
I also tried to set up DID with ext 441 to 445 with PSTN number translation xxxxx441 to xxxxx445, I guess my config was incorrect.
My config was:
Contact List: xxxxx441:441|441, xxxxx442:442|442, xxxxx443:443|443, xxxxx444:444|444, xxxxx445:445|445
With this config the result was when I called xxxxx441 extension 441 rings. If I called xxxxx442, extension 445 rings as did all the other extension as well.
Eivind
05-04-2009 02:54 AM
Dear Eivind;
For outgoing mapping, all you need to do is to add "+" to the extension in the contact list, e.g. 123456441:+441
All you need to do for translation is to set all dids next to the associated extension number, e.g. 123456441:+441|123456442:+442|123456443:+443
Alberto
05-04-2009 03:21 AM
Thanks, that solved it.
Eivind
05-04-2009 03:32 AM
Dear Eivind;
Thanks. Could you please mark the question as successfully answered so that others can benefit of it?
Alberto
05-04-2009 03:53 AM
Alberto,
I would, but since I forgot to check the box when I started this thread, I'm not able to mark og change this thread as a question. Maybe a moderator can make the changes???
Eivind
05-11-2009 07:18 AM
Unfortunately, due to software limitations, when a member creates a discussion, they have fifteen minutes from the time of posting to change it to a question (or vice versa). After that period there is no way to change it. I will investigate to see if this is something that can be changed in the future.
Thank you,
Cisco Moderation Team
