11-28-2010 09:20 PM - edited 03-21-2019 03:19 AM
I have a UC540 configured with a Skype sip trunk. The trunk is registered with Skype. I'm unable to make outgoing calls. I configured the trunk through CCA. Incomning calls are working to a Skype online number. Another problem I noticed was the the message button on the phones 7960 running SCCP has stopped working. I ran debugs the output is below. First debug is an outgoing call second debug is an attempt to get voice mail when hitting the message button equates to connecting to cue at extension 399. SIP calls are failing and SIP access to voice mail ar failing.
Any advise would be appreciated.
Andy
Below here is an outgoing call debug
home-uc540#
000845: Nov 29 23:03:39.201: //82/B922D683808A/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x87F5CA00
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 99051000122528
Called Number : 3038100583
Source IP Address (Sig ): 24.8.157.192
Destn SIP Req Addr:Port : 63.209.144.201:5060
Destn SIP Resp Addr:Port : 63.209.144.201:5060
Destination Name : sip.skype.com
home-uc540#
000846: Nov 29 23:03:39.201: //82/B922D683808A/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 24.8.157.192
Source IP Port (Media): 18328
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
000847: Nov 29 23:03:39.201: //82/B922D683808A/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 1
Disconnect Cause (SIP) : 404
Below is the output when I push the message button and the phone dials 399 which is a sip dial-peer.
home-uc540#debug ccsip call
000837: Nov 29 23:00:03.171: //78/3BE113AF8084/SIP/Call/sipSPICallInfo:
Calling Number : 202
Called Number : 399
Source IP Address (Sig ): 10.1.10.2
Destn SIP Req Addr:Port : 10.1.10.1:5060
Destn SIP Resp Addr:Port : 10.1.10.1:5060
Destination Name : 10.1.10.1
home-uc540#
000838: Nov 29 23:00:03.171: //78/3BE113AF8084/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Address (Media): 10.1.10.2
Source IP Port (Media): 18362
000839: Nov 29 23:00:03.171: //78/3BE113AF8084/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 41
Disconnect Cause (SIP) : 500
Solved! Go to Solution.
11-29-2010 10:24 AM
I use the little Search the Support Community tool in the upper right within the discussion
forum of the product. I usually put a few key words in like "skype uc500 sip"
11-29-2010 06:18 AM
Does this help?
(very recent success)
https://supportforums.cisco.com/message/3231699#3231699
https://supportforums.cisco.com/message/3231926#3231926
or this (a bit older)
11-29-2010 09:23 AM
Hi Steven,
Thank you for the links. They are very relevant and I'm sure they will help I will keep you posted. Also, I use this forum as a resource and its very beneficial.
I would like to start helping if I can, How do you search for discussions that you can provide assistance with? To find the links you provided how did you search? I found some relevant posting but not as relevant as what you found.
Anyway again thank you,
Andy
11-29-2010 10:24 AM
11-29-2010 03:07 PM
Hi Steve,
The link helped I can now recieve incoming calls across the sip trunk. However outgoing calls are not working and if i push the message button on a phone I don't get through to CUE anymore. I'm thinking it could be due to a change in the CODECs as the ccsip debugs indicate no codec.
I will continue to investigate thanks for your help.
Andy
home-uc540#debug ccsip call ?
SIP Call statistics tracing is enabled
home-uc540#term
home-uc540#terminal mon
home-uc540#terminal monitor
home-uc540#
Called Number : 399
home-uc540#
Media Stream : 1
home-uc540#
home-uc540#
Media Stream : 1
