Outgoing PSTN Trunk Preference
Ben Cruice
I've setup a UC540 with 6x FXO lines using the addin VIC card. The 6x FXO lines have been split into 2 Trunk Groups.
The client wants to be able to use 9 for dialing out on one group, and 0 for the other.
I've setup the Outgoing Call Handling Preference for access code 9 to use 1(lowest) and then 2 for the second group for Group 1.
For 0 access code it's the opposite.
However when I try to save the configuration it reverts both 0 and 9 having preference 1 and then 2.
Why does it not allow me to save two different priorities depending on the group?
0 Replies 0
