Paging to a 7921G
fisherj
ephone-dn 28
number 622
paging ip 239.1.1.2 port 2000
paging group 2
ephone 6
mac-address 0000.0000.0000
paging-dn 28
type 7921
button 1:10 2:11 3:12 4:13 6:2
When calling 622 from a 7965 I cannot recieve any pages on the 7921 phones.  Any thoughts?
P.S. I installed a 7911 and inserted in the same paging-dn 28 and it works ok.
Doesn't look like multicast is supported on that AP.  Marcos wrote an article describing the limitation.
https://supportforums.cisco.com/docs/DOC-9495
You'll need to change your paging from multicast to unicast to resolve the problem.
Cole
This is most likely due to the wireless network not passing multicast traffic.  Are you using autonomous APs or lightweight?
Cole
The 7921s are working off (AIR-AP521G-A-K9).   Reading more I see this is an autonomous ap that does not support multicast, or does it?  I do not have a controller to turn this into a light weight...
Cole
fisherj
Thanks for the information.  We changed the paging to unicast and all works well..  Thanks again!
