523
Highlighted
Beginner
Parking slot and blf
Dear Dan,
How you do "blf+cp" for parking slot number ?
In draytek IPPBX3510 :
Parking Server Number : 777
Parking Slot Range . 81 to 90
When i have a call, i forward it to 777 and i receive a message from pbx with slot number like "81"
In cisco spa5xx, i have make a
fnc=blf+cp;sub=81@10.0.0.254;ext=81@10.0.0.254;nme=81
but my "led" is always "amber" .. is still my "draytek error" ?
I just view "SIP/2.0 404 Not Found" from draytek response to subscrive event.
Mon Jan 13 2014 11:31:11 GMT+0100 (CET)::10.0.0.86::SUBSCRIBE sip:81@10.0.0.254 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.86:5060;branch=z9hG4bK-fbc60477
From: "203" <sip:203@10.0.0.254>;tag=b01596ef12af7b62
To: <sip:81@10.0.0.254>
Call-ID: 75ba63b3-f5d1756e@10.0.0.86
CSeq: 20696 SUBSCRIBE
Max-Forwards: 70
Contact: "203" <sip:203@10.0.0.86:5060>
Accept: application/dialog-info+xml
Expires: 1800
Event: dialog
User-Agent: Cisco/SPA501G-7.5.5
Content-Length: 0
Mon Jan 13 2014 11:31:11 GMT+0100 (CET)::10.0.0.86::<134>
Mon Jan 13 2014 11:31:11 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]<<10.0.0.254:5060
Mon Jan 13 2014 11:31:11 GMT+0100 (CET)::10.0.0.86::SIP/2.0 404 Not Found
To: <sip:81@10.0.0.254>;tag=7564
Server: Draytek Mars 1.0.0
Content-Length: 0
Mon Jan 13 2014 11:31:11 GMT+0100 (CET)::10.0.0.86::<151>SUBS Failed 19 27 17
1 REPLY 1
Highlighted
Advocate
It's generic discussion forum, you should not ask just me personally here ...
Well. Draytek is just rejecting the subscription. I'm not fammilar with Draytek so I don't know it's bug or not. If you thing the Draytek should publish parl slot 81 state under the name 81 then ask Draytek's support for help, but it sounds suspicious a lot for me. If Draytek is publishing park slot 81 state, I expect other name for it than just 81.
All at all, it seems not to be something that Cisco can help you with.
