Phone flat-profile xml for WEP and WPA-PSK
ksubashc
                   Hi, I am from CCA team, require telephony-service commands specific to "WEP" and "WPA-PSK" wireless security modes.
Currently, CCA generates the commands for "disabled" and "WPA2_PSK" security mode cases.
Following is the commands for WPA2_PSK;
telephony-service
service phone SPA525-Encryption-key cisco1234
service phone SPA525-wifi-on yes
service phone SPA525-protocol SPCP
service phone SPA525-auto-detect-sccp yes
service phone SPA525-http-write yes
service phone SPA525-SSID myvoice
service phone SPA525-readonly no
service phone SPA525-Encryption-type WPA2_PSK
create cnf-files
Following xml pushed auomatically to SPA525G after CCA deleiver the above commands to UC520
<flat-profile>
<SPA525-SSID>myvoice</SPA525-SSID>
<SPA525-Encryption-type>WPA2_PSK</SPA525-Encryption-type>
<SPA525-Encryption-key-code></SPA525-Encryption-key-code>
<SPA525-Encryption-key>cisco1234</SPA525-Encryption-key>
<SPA525-protocol>SPCP</SPA525-protocol>
<SPA525-auto-detect-sccp>yes</SPA525-auto-detect-sccp>
<SPA525-wifi-on>yes</SPA525-wifi-on>
<SPA525-readonly>no</SPA525-readonly>
<SPA525-http-write>yes</SPA525-http-write>
</flat-profile>
Instead of WPA2_PSK, I have tried by replacing the Encryption-type to WEP or WPA_PSK .But the wireless connectivity get failed .
Can you please let me know sample xml or command specific to the security modes?
nseto
Level 6
Level 6
You can download the spc file from
http://www.cisco.com/cisco/software/release.html?mdfid=282414147&softwareid=282562500&release=7.4.9 which allows you to generate the xml file.
I did that and I see the following options for the security.
Disable
nseto
Level 6
Level 6
Disable
Thanks very much for your help. I executed the spc exe and got the xml which contains tags with the values as you mentioned. Now I am trying to push the xml from CCA to phone as part of configuring a ssid from CCA. I am using this approach, http://10.1.1.12/admin/resync?http://192.168.10.11:8088/wo/phone for send the xml.
Earlier I tried some older version of tool spa525g-sccp-7-2-5-spc-win32-i386.exe which just generated tags without values.
