Phonepower as a SIP provider for UC540
wayne
has anyone had any experience stting up a SIP trunk on the UC540 with phonepower as the provider? I am having some issues with basic setup. I can't seem to get the UC540 to register with the provider. thanks.
Wayne
David Trad
Hi Wayne,
Have they given you configuration information to assist you with the setup process?
If they have can you post it without all the sensitive information just to be sure it is everything you need to get it working.
Also as per our private inboxing, can you advise if your UC is WAN facing or if you have a router in front of it?
Cheers,
David Trad.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
