Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1172
mark
Beginner
Phones that are no longer in use
Is there a command I can run on the UC560 to find out which phones are no longer in use.  I have a customer with about 90 phones and I know some of them have been replaced so I want to free up the license and clean it up.  How can I find out CLI what phones to remove.
1 ACCEPTED SOLUTION
johschaf
Enthusiast
show ephone unregistered will show you what phones are not registered to the UC.
However, I'm not sure if that is going to help you here, as only registered phones utilize a license. Removing the unregistered phones from the config would really just be to keep the config clean.
If you need to free up some licenses and you aren't using the FXS ports, that put the port into a shutdown state to free a license.
Hope this helps.
-john
2 REPLIES 2
johschaf
Enthusiast
Hope this helps.
-john
Thank you very much, I was able to delete the phones not in use and clean it up.  Thanks!
