09-07-2010 08:20 AM - edited 03-21-2019 02:58 AM
I have 0 as acces code for my spanish dial plan. I need an extension to be able to place calls without dialing 0, is it possible?. This extension is connected to a credit card reader, which I have no access to the configuration menu. Before installing the UC, the card reader was connected to the PSTN directly, and it does not dial any access code.
Thanks.
09-07-2010 11:45 AM
Though not exactly what you are looking to do, the following link provides the concepts for making this work.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Here's an example:
voice translation-rule 1
rule 1 // /0/
voice translation-profile 1
translate called 1
dial-peer voice 1 voip
translation-profile incoming 1
answer-address 1234
The above configuration would prefix a 0 on any call originating from extension 1234.
Hope this helps.
Brandon
09-08-2010 02:18 AM
Hi Brandon,
Thanks for the response. What I need is just append a 0 for the outgoing calls originated from a specific extension. I think your example could work in my scenario, I am going to try it.
Regards!
09-08-2010 07:37 AM
Hi Brandon,
It didn't work. If I'm right, CME appends a digit after gathering the whole digits. If I start dialing a PSTN number without 0, as soon as the CME doesn't find a pattern in the dial plan it returns the busy tone, as it should be.
What I'm looking for is a way to make a specific extension able to make outbound calls without dialing the access code '0', while the rest of the extensions continue dialing '0'.
Any suggestions?
09-08-2010 07:47 AM
If PSTN access is FXO then you can try putting "CO_Line" on the phone buttons, which I have found when pressed are on the dial tone of the telephone company, and no access code required.
09-08-2010 08:32 AM
Unfortunately is a RDSI connection. With a DDI associated.
09-08-2010 08:44 AM
I haven't tested this, but wondering if you could add a dummy dial peer that would give the call something to match until the translation can be completed such as:
destination-pattern .T
session target ipv4:1.1.1.1 (dummy IP address)
Theoretically, calls would never hit this dial peer. It would just match the outgoing call initially until the translation profile is applied.
Brandon
