12-22-2013 04:55 PM - edited 03-21-2019 07:58 AM
Dear,
i have fully integrate :
- cisco spa 50X
- CRM
- Extension mobility
- IPPBX
And all "not dependant platform", it's work on linux, windows, mac, ... over VPN or over internet ...
but my only problem is BLF and "subscribe" .. with spa500S console.
My question is : is there a way to control CISCO SPA 500S (attendant console) remotely ? by script, php.. ?
my issue is : cisco spa500S don't retry to subscribe with a new call transaction but always with a old... As a see in this forum, many persoon have problem with "subscribe" on spa500S. It's not possible to user to see 30 led blink yellow.. and all phone are online and registered.
Witch setting must i configure for that ?
Cisco Spa500S have some programming sample somewhere i can download ?
PS : i see, i have only this sip error : 481 : call transaction/leg don't exist ..
Regards.
Solved! Go to Solution.
01-07-2014 07:21 AM
Subscription-State: terminated;reason=noresourceAnd after the 203 go power on, somebody forget the SUBSCRIBE and do not send the NOTIFY to 394.
394 should send SUBSCRIBE peridically (when subscription terminated). If it will not do it, then it seems to be Cisco's bug.
Try to shorten Sub Max Expires to something like 30 second or so. May be the phone is using expire timer dedicated to active subscriptions instead the one for failed subscriptions in our case ...
01-07-2014 07:07 AM
So, most relevant part are here:
Tue Jan 07 2014 14:28:53 GMT+0100 (CET)::SUBSCRIBE sip:203@10.0.0.254 SIP/2.0Via: SIP/2.0/UDP 10.0.0.84:5060;branch=z9hG4bK-8ddd94e4
To: <203>203>
Call-ID: 53c4e17-8c2fee7e@10.0.0.84
CSeq: 33996 SUBSCRIBE
Max-Forwards: 70
Contact: "394" <394>394>
Accept: application/dialog-info+xml
Expires: 1800
Event: dialog
User-Agent: Cisco/SPA504G-7.5.5
Content-Length: 0
Tue Jan 07 2014 14:28:53 GMT+0100 (CET)::NOTIFY sip:394@10.0.0.84:5060 SIP/2.0Via: SIP/2.0/UDP 10.0.0.254:5060;branch=z9hG4bK-Mlb-3409;rport
To: "394" <394>;tag=32daf143ee67c542394>
CSeq: 100269 NOTIFY
Max-Forwards: 70
User-Agent: Draytek Mars 1.0.0
Event: dialog
Content-Type: application/dialog-info+xml
Content-Length: 207
terminated
Tue Jan 07 2014 14:28:53 GMT+0100 (CET)::SIP/2.0 200 OKVia: SIP/2.0/UDP 10.0.0.84:5060;branch=z9hG4bK-8ddd94e4
To: <203>;tag=21419203>
Contact: <203>203>
Server: Draytek Mars 1.0.0
Event: dialog
Expires: 1800
Content-Length: 0
Tue Jan 07 2014 14:38:38 GMT+0100 (CET)::NOTIFY sip:394@10.0.0.84:5060 SIP/2.0Via: SIP/2.0/UDP 10.0.0.254:5060;branch=z9hG4bK-XUT-5011;rport
CSeq: 100453 NOTIFY
Max-Forwards: 70
Event: dialog
Content-Length: 207
terminated
Tue Jan 07 2014 14:38:38 GMT+0100 (CET)::SIP/2.0 481 Call Leg/Transaction Does Not ExistTo: "394" <394>;tag=32daf143ee67c542394>
CSeq: 100453 NOTIFY
Server: Cisco/SPA504G-7.5.5
Content-Length: 0
Lets analyze.
[1] is the SUBSCRIBE packet from 394 to Draytek
[2] is NOTIFYcation from Draytek related to subscription with Subscription-State: terminated
[3] is the response to SUBSCRIBE
[4] is another NOTIFY with Subscription-State: terminated
Taken from RFC3265:
A subscription is destroyed when a notifier sends a NOTIFY request with a "Subscription-State" of "terminated".
So, subscription of 203 state request is accepted [3] by Draytek, but terminated [2] immediately. The further NOTIFY, like [4] are not part of of valid subscription, so they are rejected with 481 error code.
Conclusion ? 394 is not able to subscribe the 203 state, so button blink orange.
Problem is on Draytek side. I assume it doesn't distinguish between extension that doesn't exist and and extension that's not reachable just now. Describing it in Q.850 terms - it treat code 20 (subscriber absent) the same way as code 1 (unassigned number).
On the other side, I'm not sure what state you wish to see here. All at all, Draytek's behavior related to SUBSCRIPTION to unregistered extension needs to be configured on Draytek.
And rest seems to be obvious. The 203 will start and register to Draytek sometime. Next subscription from 394 will not be terminated anymore, so button become solid green. 394 should retry terminated subscription within 10 second (unless Sub Retry Intvl configured to non-default value by you). Of course, you may not wait 10 second, you may reboot 394. It will trigger new subscription as well.
01-08-2014 06:02 AM
Dear Dan,
If someone from cisco and draytek "engineer" can confirm that
cisco spa don't SUBSCRIBE if "noressource" ?
Here another log : 203 and 394 ..each monitor the other
each :
Sub Max Expires: 180
Sub Retry Intvl: 60
And always same, who first boot, have the blink orange
I know now too why i must "hard reboot like power off power on".
When i reboot the phone by http://10.0.0.86/admin/reboot ..the registration of the extension is "directly removed" from draytek.
if i hard reboot like "power off, power on", the registration of the extension still in "draytek"..because registration time of 300s.
Thanks Dan, your help is many apprecied and for me you have give the "bug" and the "solution"
I hope cisco and draytek can find a solution for me.
server listening 0.0.0.0:2514
Wed Jan 08 2014 14:42:47 GMT+0100 (CET)::10.0.0.86::<159>fu:0:0dd90, 6.2.16 6.2.17 1
Wed Jan 08 2014 14:42:51 GMT+0100 (CET)::10.0.0.84::<159>fu:0:0e45a, 6.2.16 6.2.17 1
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::<134>request reboot type=4 reason=User Triggered(10)
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]->10.0.0.254:5060{422)
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::SUBSCRIBE sip:394@10.0.0.254 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.86:5060;branch=z9hG4bK-2f695735
To: <394>;tag=3741394>
Call-ID: cf41291e-ea9f6f5@10.0.0.86
CSeq: 32532 SUBSCRIBE
Max-Forwards: 70
Contact: "203" <203>203>
Expires: 0
Event: dialog
User-Agent: Cisco/SPA501G-7.5.5
Content-Length: 0
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]->10.0.0.254:5060{687)
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::REGISTER sip:10.0.0.254 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.86:5060;branch=z9hG4bK-965a821e
To: "203" <203>203>
Call-ID: 9b036c0b-8d8441b@10.0.0.86
CSeq: 52046 REGISTER
Max-Forwards: 70
Authorization: Digest username="203",realm="abcd.be",nonce="c939ff72e8f7cb18811bc891dac87a89",uri="sip:10.0.0.254",algorithm=MD5,response="71aff0c67e7cf7c35fcd164bfee41429",opaque="66be48cdcc0397b1219cf76582678f12"
Contact: "203" <203>;expires=0203>
Content-Length: 0
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE, MESSAGE
Supported: replaces
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]<<10.0.0.254:5060
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::NOTIFY sip:203@10.0.0.86:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.254:5060;branch=z9hG4bK-aHV-28866;rport
To: "203" <203>;tag=942c2b0aa482fdf9203>
CSeq: 114786 NOTIFY
Subscription-State: terminated;reason=timeout
Max-Forwards: 70
Event: dialog
Content-Length: 207
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]->10.0.0.254:5060{278)
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::SIP/2.0 200 OK
CSeq: 114786 NOTIFY
Server: Cisco/SPA501G-7.5.5
Content-Length: 0
Contact: <394>394>
Event: dialog
Expires: 0
Content-Length: 0
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::<151>[0]SubOK. NextSub in 1 (1)
To: "203" <203>;tag=3683203>
Content-Length: 0
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::<151>[0]UnRegOK
Wed Jan 08 2014 14:43:10 GMT+0100 (CET)::10.0.0.86::<159>fu:0:0de13, 4.71 1
Wed Jan 08 2014 14:43:12 GMT+0100 (CET)::10.0.0.86::<159>first_rule is .
Wed Jan 08 2014 14:43:12 GMT+0100 (CET)::10.0.0.86::<159>first type is 0.
Wed Jan 08 2014 14:43:12 GMT+0100 (CET)::10.0.0.86::<159>fu:0:0df50, 5.1.12 5.1.14 5.1.19 6.8 7.13 1
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::<134>request reboot type=4 reason=User Triggered(10)
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]->10.0.0.254:5060{422)
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::SUBSCRIBE sip:203@10.0.0.254 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.84:5060;branch=z9hG4bK-6df838d9
To: <203>;tag=7940203>
Call-ID: a44f5150-14359d1a@10.0.0.84
CSeq: 1001 SUBSCRIBE
Max-Forwards: 70
Expires: 0
Event: dialog
Content-Length: 0
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]->10.0.0.254:5060{679)
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::REGISTER sip:10.0.0.254 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.84:5060;branch=z9hG4bK-e39ea229
To: "394" <394>394>
Call-ID: 8a1cfb96-149f81d8@10.0.0.84
CSeq: 57486 REGISTER
Max-Forwards: 70
Authorization: Digest username="394",realm="abcd.be",nonce="2f612d4d2e6890c43f04bcc8754fcc32",uri="sip:10.0.0.254",algorithm=MD5,response="c0995104aabe168581998a243aa06647",opaque="a0b3688c5cea32f7d8f37fbbe653d4b4"
Contact: "394" <394>;expires=0394>
Content-Length: 0
Supported: replaces
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]<<10.0.0.254:5060
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::NOTIFY sip:394@10.0.0.84:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.254:5060;branch=z9hG4bK-fkf-22299;rport
To: "394" <394>;tag=67d674e76e57760a394>
CSeq: 114787 NOTIFY
Max-Forwards: 70
Event: dialog
Content-Length: 207
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]->10.0.0.254:5060{279)
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::SIP/2.0 200 OK
CSeq: 114787 NOTIFY
Content-Length: 0
Contact: <203>203>
Event: dialog
Expires: 0
Content-Length: 0
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::<151>[0]SubOK. NextSub in 1 (1)
To: "394" <394>;tag=16787394>
Content-Length: 0
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::<151>[0]UnRegOK
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::<159>fu:0:0e4dd, 4.71 1
Wed Jan 08 2014 14:43:17 GMT+0100 (CET)::10.0.0.84::<159>first_rule is .
Wed Jan 08 2014 14:43:17 GMT+0100 (CET)::10.0.0.84::<159>first type is 0.
Wed Jan 08 2014 14:43:17 GMT+0100 (CET)::10.0.0.84::<159>fu:0:0e5bd, 5.1.10 5.1.12 5.1.14 5.1.19 6.8 7.13 1
Wed Jan 08 2014 14:43:50 GMT+0100 (CET)::10.0.0.86::<143> gateway ip: 10.0.0.254
Wed Jan 08 2014 14:43:50 GMT+0100 (CET)::10.0.0.86::<134>SCCPTCP:ERR:Can't bind to a000056:5060 errno=49
Wed Jan 08 2014 14:43:50 GMT+0100 (CET)::10.0.0.86::<159>IDBG: LS, 270-4d8
Wed Jan 08 2014 14:43:50 GMT+0100 (CET)::10.0.0.86::<159>IDBG: SOK
Wed Jan 08 2014 14:43:50 GMT+0100 (CET)::10.0.0.86::<159>IDBG: st-0
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<151>Resolving 10.0.0.254
save param: 548 = 0 548
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<159>[BKpic]Loading text background image
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<134>[0]Reg Addr Change(0) 0:0->a0000fe:5060
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]->10.0.0.254:5060{464)
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::REGISTER sip:10.0.0.254 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.86:5060;branch=z9hG4bK-2ebe91f
To: "203" <203>203>
CSeq: 52047 REGISTER
Max-Forwards: 70
Contact: "203" <203>;expires=3600203>
Content-Length: 0
Supported: replaces
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]<<10.0.0.254:5060
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::SIP/2.0 401 Unauthorized
To: "203" <203>;tag=32119203>
WWW-Authenticate: Digest realm="abcd.be", nonce="653f2401e5a8ba0cd4e704df6a8cf22a", opaque="9a3f97ffe4bce0827f2f601184ba1a9e"
Content-Length: 0
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]->10.0.0.254:5060{690)
Via: SIP/2.0/UDP 10.0.0.86:5060;branch=z9hG4bK-a7107734
To: "203" <203>203>
CSeq: 52048 REGISTER
Max-Forwards: 70
Authorization: Digest username="203",realm="abcd.be",nonce="653f2401e5a8ba0cd4e704df6a8cf22a",uri="sip:10.0.0.254",algorithm=MD5,response="379b077565f5c8c1f5fed96794fa76dc",opaque="9a3f97ffe4bce0827f2f601184ba1a9e"
Content-Length: 0
Supported: replaces
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::SIP/2.0 200 OK
To: "203" <203>;tag=5365203>
Contact: "203" <203>;expires=300203>
Content-Length: 0
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<151>[0]RegOK. NextReg in 299 (1)
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<159>[BKpic]Download picture from http://10.0.0.1/cisco/spa/rivagelogo.bmp
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<159>[create_tcp_netstrm1] use async to create tcp connection
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<159>connect succeed
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<159>[create_tcp_netstrm1] connect SUCCEED
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<134>content len (hdr) =990
Wed Jan 08 2014 14:43:51 GMT+0100 (CET)::10.0.0.86::<159>[BKpic]Same URL, not load
Wed Jan 08 2014 14:43:52 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]->10.0.0.254:5060{416)
Wed Jan 08 2014 14:43:52 GMT+0100 (CET)::10.0.0.86::SUBSCRIBE sip:394@10.0.0.254 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.86:5060;branch=z9hG4bK-6fd93061
To: <394>394>
Call-ID: 190a1745-a5ea075c@10.0.0.86
CSeq: 4154 SUBSCRIBE
Max-Forwards: 70
Expires: 1800
Event: dialog
Content-Length: 0
Wed Jan 08 2014 14:43:52 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]<<10.0.0.254:5060
Wed Jan 08 2014 14:43:52 GMT+0100 (CET)::10.0.0.86::NOTIFY sip:203@10.0.0.86:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.254:5060;branch=z9hG4bK-opA-18459;rport
To: "203" <203>;tag=99757e316935ed60203>
CSeq: 114799 NOTIFY
Max-Forwards: 70
Event: dialog
Content-Length: 207
Wed Jan 08 2014 14:43:52 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]->10.0.0.254:5060{280)
Wed Jan 08 2014 14:43:52 GMT+0100 (CET)::10.0.0.86::SIP/2.0 200 OK
CSeq: 114799 NOTIFY
Content-Length: 0
To: <394>;tag=26261394>
Contact: <394>394>
Event: dialog
Expires: 1800
Content-Length: 0
Wed Jan 08 2014 14:43:52 GMT+0100 (CET)::10.0.0.86::<151>[0]SubOK. NextSub in 1799 (1)
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fs:052982:053230:262144
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fls:fafuffffff:9:5907:61200
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fbr:0:3000:3000:0df50:0034:0033:7.5.5
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:01:0:002e:upg:app:2:7.5.2b
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:02:0:002f:upg:app:0:7.5.3
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:03:0:0030:upg:app:1:7.5.3
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:04:0:0031:upg:app:2:7.5.3
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:05:0:0032:upg:app:0:7.5.2b
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:06:0:0033:upg:app:1:7.5.2b
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:07:0:0034:upg:app:2:7.5.2b
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:08:0:0035:upg:app:0:7.5.3
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:09:0:0036:upg:app:1:7.5.3
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:0a:0:0037:upg:app:2:7.5.3
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:0b:0:0038:upg:app:0:7.5.4
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:0c:0:0039:upg:app:1:7.5.4
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:0d:0:003a:upg:app:2:7.5.4
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:0e:0:003b:upg:app:0:7.5.5
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:0f:0:003c:upg:app:1:7.5.5
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fhs:10:0:003d:upg:app:2:7.5.5
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>dhcp opt 66: ""
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>dhcp opt 160: ""
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>dhcp opt 159: ""
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>dhcp opt 150: ""
Wed Jan 08 2014 14:43:54 GMT+0100 (CET)::10.0.0.86::<159>fu:0:0df8a, 5.1.1 1
Wed Jan 08 2014 14:43:57 GMT+0100 (CET)::10.0.0.84::<143> gateway ip: 10.0.0.254
Wed Jan 08 2014 14:43:57 GMT+0100 (CET)::10.0.0.84::<134>SCCPTCP:ERR:Can't bind to a000054:5060 errno=49
Wed Jan 08 2014 14:43:57 GMT+0100 (CET)::10.0.0.84::<159>IDBG: LS, 270-4d8
Wed Jan 08 2014 14:43:57 GMT+0100 (CET)::10.0.0.84::<159>IDBG: SOK
Wed Jan 08 2014 14:43:57 GMT+0100 (CET)::10.0.0.84::<159>IDBG: st-0
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<151>Resolving 10.0.0.254
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<159>[BKpic]Loading text background image
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkcfwd in Idle key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkdnd in Idle key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkcfwd in Progressing key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkdnd in Progressing key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkcfwd in Releasing key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkdnd in Releasing key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkcfwd in Hold key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkdnd in Hold key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkcfwd in Shared Active key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkdnd in Shared Active key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkcfwd in Shared Held key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<3>PGSK: chkdnd in Shared Held key list is not defined
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<134>[0]Reg Addr Change(0) 0:0->a0000fe:5060
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]->10.0.0.254:5060{457)
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::REGISTER sip:10.0.0.254 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.84:5060;branch=z9hG4bK-c806008a
To: "394" <394>394>
CSeq: 57487 REGISTER
Max-Forwards: 70
Contact: "394" <394>;expires=3600394>
Content-Length: 0
Supported: replaces
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]<<10.0.0.254:5060
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::SIP/2.0 401 Unauthorized
To: "394" <394>;tag=4279394>
WWW-Authenticate: Digest realm="abcd.be", nonce="6f573885be97de82f39b5b12259e2184", opaque="fa2577ba9c59cb03c7ea95278b958ced"
Content-Length: 0
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]->10.0.0.254:5060{682)
Via: SIP/2.0/UDP 10.0.0.84:5060;branch=z9hG4bK-76ceae0e
To: "394" <394>394>
CSeq: 57488 REGISTER
Max-Forwards: 70
Authorization: Digest username="394",realm="abcd.be",nonce="6f573885be97de82f39b5b12259e2184",uri="sip:10.0.0.254",algorithm=MD5,response="86819b55dfd0c4b511fb9142977d13df",opaque="fa2577ba9c59cb03c7ea95278b958ced"
Content-Length: 0
Supported: replaces
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::SIP/2.0 200 OK
To: "394" <394>;tag=7836394>
Contact: "394" <394>;expires=300394>
Content-Length: 0
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<151>[0]RegOK. NextReg in 299 (1)
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]<<10.0.0.254:5060
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.86::NOTIFY sip:203@10.0.0.86:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.254:5060;branch=z9hG4bK-gta-27899;rport
CSeq: 114801 NOTIFY
Subscription-State: active
Max-Forwards: 70
Event: dialog
Content-Length: 207
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]->10.0.0.254:5060{313)
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.86::SIP/2.0 481 Call Leg/Transaction Does Not Exist
CSeq: 114801 NOTIFY
Content-Length: 0
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<159>[BKpic]Download picture from http://10.0.0.1/cisco/spa/rivagelogo.bmp
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<159>[create_tcp_netstrm1] use async to create tcp connection
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<159>connect succeed
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<159>[create_tcp_netstrm1] connect SUCCEED
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<134>content len (hdr) =990
Wed Jan 08 2014 14:43:58 GMT+0100 (CET)::10.0.0.84::<159>[BKpic]Same URL, not load
Wed Jan 08 2014 14:43:59 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]->10.0.0.254:5060{417)
Wed Jan 08 2014 14:43:59 GMT+0100 (CET)::10.0.0.84::SUBSCRIBE sip:203@10.0.0.254 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.84:5060;branch=z9hG4bK-d5a05538
To: <203>203>
Call-ID: c0c1e1d4-bc5ea5fe@10.0.0.84
CSeq: 46861 SUBSCRIBE
Max-Forwards: 70
Expires: 1800
Event: dialog
Content-Length: 0
Wed Jan 08 2014 14:43:59 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]<<10.0.0.254:5060
Wed Jan 08 2014 14:43:59 GMT+0100 (CET)::10.0.0.84::NOTIFY sip:394@10.0.0.84:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.254:5060;branch=z9hG4bK-CeF-5520;rport
To: "394" <394>;tag=8fef9fdc6738bf96394>
CSeq: 114802 NOTIFY
Max-Forwards: 70
Event: dialog
Content-Length: 207
Wed Jan 08 2014 14:43:59 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]->10.0.0.254:5060{279)
Wed Jan 08 2014 14:43:59 GMT+0100 (CET)::10.0.0.84::SIP/2.0 200 OK
CSeq: 114802 NOTIFY
Content-Length: 0
To: <203>;tag=15527203>
Contact: <203>203>
Event: dialog
Expires: 1800
Content-Length: 0
Wed Jan 08 2014 14:43:59 GMT+0100 (CET)::10.0.0.84::<151>[0]SubOK. NextSub in 1799 (1)
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fs:048239:048378:262144
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fls:fuafffffff:2:150:58192
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fbr:0:3000:3000:0e5bd:0016:0015:7.5.5
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fhs:01:0:0001:upg:app:M:7.4.9c
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fhs:02:0:0002:upg:app:0:7.5.2b
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fhs:03:0:0003:upg:app:1:7.5.2b
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fhs:04:0:0004:upg:app:2:7.5.2b
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fhs:05:0:0005:upg:app:0:7.5.4
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fhs:06:0:0006:upg:app:1:7.5.4
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fhs:07:0:0007:upg:app:2:7.5.4
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fhs:08:0:0008:upg:app:0:7.5.5
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fhs:09:0:0009:upg:app:1:7.5.5
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fhs:0a:0:000a:upg:app:2:7.5.5
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>dhcp opt 66: ""
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>dhcp opt 160: ""
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>dhcp opt 159: ""
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>dhcp opt 150: ""
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<134>resync rule: /spa504G.cfg
Wed Jan 08 2014 14:44:01 GMT+0100 (CET)::10.0.0.84::<159>fu:0:0e5f7, 5.1.1 1
Wed Jan 08 2014 14:47:45 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]->10.0.0.254:5060{690)
Wed Jan 08 2014 14:47:45 GMT+0100 (CET)::10.0.0.86::REGISTER sip:10.0.0.254 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.86:5060;branch=z9hG4bK-8edab108
To: "203" <203>203>
CSeq: 52049 REGISTER
Max-Forwards: 70
Content-Length: 0
Supported: replaces
Wed Jan 08 2014 14:47:45 GMT+0100 (CET)::10.0.0.86::<134>[0:5060]<<10.0.0.254:5060
Wed Jan 08 2014 14:47:45 GMT+0100 (CET)::10.0.0.86::SIP/2.0 200 OK
To: "203" <203>;tag=8261203>
Content-Length: 0
Wed Jan 08 2014 14:47:45 GMT+0100 (CET)::10.0.0.86::<151>[0]RegOK. NextReg in 299 (1)
Wed Jan 08 2014 14:47:52 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]->10.0.0.254:5060{682)
Wed Jan 08 2014 14:47:52 GMT+0100 (CET)::10.0.0.84::REGISTER sip:10.0.0.254 SIP/2.0
Via: SIP/2.0/UDP 10.0.0.84:5060;branch=z9hG4bK-801f790d
To: "394" <394>394>
CSeq: 57489 REGISTER
Max-Forwards: 70
Content-Length: 0
Supported: replaces
Wed Jan 08 2014 14:47:52 GMT+0100 (CET)::10.0.0.84::<134>[0:5060]<<10.0.0.254:5060
Wed Jan 08 2014 14:47:52 GMT+0100 (CET)::10.0.0.84::SIP/2.0 200 OK
To: "394" <394>;tag=13339394>
Content-Length: 0
Wed Jan 08 2014 14:47:52 GMT+0100 (CET)::10.0.0.84::<151>[0]RegOK. NextReg in 299 (1)
01-08-2014 07:05 AM
Problem is on Draytek side ... it treat code 20 (subscriber absent) the same way as code 1 (unassigned number).
"Problem" is not the same as "bug". It may be intended behavior. It's questionable what status should be reported in the case the extension is not reachable. It is case-by-case decision.
It subscribe. But such subscription is terminated immediately by Draytek. Client can do not so much with it.
I know now too why i must "hard reboot like power off power on".When i reboot the phone by http://10.0.0.86/admin/reboot ..the registration of the extension is "directly removed" from draytek.
It's expected behavior. Phone should unregister whenever possible before before it go offline. PBX can recognize missing phone by timeout, but it's so late.
According your log:
Wed Jan 08 2014 14:43:16 GMT+0100 (CET)::10.0.0.84::SUBSCRIBE ...
... the Cisco will try to subscribe periodically. Not sure what solution you are wishing for. If you want the Draytek not to terminate subscription despite the extension unavaiable, then ask Draytek. I'm not sure how the Cisco can help you ...
