Port Forwarding UC320 multiple port range
cachorropr
Beginner
Beginner
We need to able to select a range of ports when configuring a Port Forward on a UC320 install. Using a "-" between ports is not available for use. Anybody know of a way of doing this?
Carlos Bermudez
rbordner
Carlos,
I will add an enhancment request to add ability to enter a range of ports into the management interface.
Can you give me an example of a range you would like to enter?
And how many different entries you would like to enter.
Randy
Hey Randy,
This is related to UDP connections. I have a small web server behind a UC320 that needs a range of 100 UDP ports open for clients to access it for a specific application. I think the UC300 should have the ability to access all the range of the port spectrum instead of just 25. You are limiting the use of the product.
Carlos
Carlos,
Thanks for the additional information.  I will add this to the enhancement item list.
Randy
