07-27-2012 11:12 AM - edited 03-21-2019 06:05 AM
Is it possible to configure the t.37 off ramp on a uc540 to send faxes via email or some type of print driver from local pc's? On ramp and off ramp are installed via cca and on ramp routing works great.
Solved! Go to Solution.
07-28-2012 03:30 AM
Yes it's possible using software that has the 'fax to email' capability missing in Windows.
Here is one that works very nicely:
07-27-2012 07:16 PM
Hello Greg,
It is not possible to send faxes from a PC using the UC540.
-john
07-27-2012 11:31 PM
Just to add to what John already said. If you need to send PSTN faxes from a local pc you may need consider network fax machine which must be connected to FXS port of the UC, or using modem of the PC connected to the FXS port of the UC.
Best regards,
Alex
07-28-2012 03:30 AM
07-28-2012 09:33 AM
Thank you for the responses.
I have run across the sandlerco site. Does anyone have any experience with the software?
07-28-2012 03:29 PM
As mentioned above: it works as described.
Thank you for the nice rating and good luck!
