06-29-2011 06:18 PM - edited 03-21-2019 04:17 AM
Hi all
Not sure if this is a bug or not.
If im on a call or off hook on my FXS ext 101 and i call the main number which is routing to a hunt group 200 which rings exts 100 and 101 together, ext 100 rings which is fine but when i finish my call on ext 101 should it not ring with the new call, because it doesnt. Could be a problem if your having lots of calls coming in and you are using a bell on the fxs port to notify calls are coming in, which is typical in a warehouse setup.
Dave
06-29-2011 08:20 PM
Hi Dave,
Sounds like the system is not re-sending the alert to the FXS port, maybe this is just a limitation of the FXS?
Cheers,
David.
07-10-2011 11:57 AM
On UC320, how do you setup a hunt group that contains both FXO ports and FXS port? The CCA doesn't allow that. If I can do that, then I can resolve my paging problem. Please see my previous thread:
https://supportforums.cisco.com/message/3388571#3388571
Your help is appreciated. Thanks
Pramod
