Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
2120
jcartier
Beginner
Power Injector - SPA500 Series
Hi All,
I was told their is currently no Cisco PoE injector available for the SPA500 series phones...is this true?
If so, has anyone had any experience with a third-party power injector?
Our scenario is where we need to power two SPA500 phones from a non-PoE switch.
3 REPLIES 3
Alberto Montilla
Dear sir;
Please use the PA100 power adaptor for the SPA500 phones if your switch is not POE. You can purchase it from same partner you got the phones. It is not a power injector but power adaptor.
Regards;
Alberto
I'm guessing given the nature of the question, the person wants to use PoE rather than a power brick...
I've heard good things about powerdsine power injectors. SPA series seems to use standard PoE so chances are, anything is likely to work. There is a PDF floating around with power consumption - they are low enough to work with anything though.
Steve
CTRLITINC
Beginner
You are able to use either the power adapter specifically made for the phone or a PoE Injector. I would be inclined to use the PoE Injector becuase you can use w/ any PoE device and not a specific phone model. You can also pick up a PoE Injector at one of the big box computer stores(in use Fry's or Micro Center).
Any PoE injector should work due to PoE being a standard and I have personally used the PoE Injector on the SPA504G and SPA525G phones when a PoE switch failed, so they are great to have handy.
Steve Wofford
Call Ctrl Call Manager for
SPA900 - SPA500 IP Phones
