Pre Purchase Question - Steering Digits
gavin.tobin
About to purchase the UC320W and had a quick look at the online emulator.
Plan to use with a single analogue trunk and also a SIP trunk.
Is it possible to have a separate steering digit for the outside line, ie dial 8 for outside analogue trunk or dial 9 for outside SIP trunk?
Or is it possible to modify the dial plan that certain types of calls are forced out a particular route, i.e. all mobile calls are forced out the analogue trunk and never over the SIP (this is what I want to achieve).
Thanks in advance
GT
wenyang
Level 4
Level 4
Hi GT,
Yes, you can have a separate steering digit for the different outside line. But you can't have different dial plan for the different route.
Best Regards,
Wendy Yang
