Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
583
gstoscano
Beginner
Problem FXO 3-4 (Not Registered)
Hi, we installed a UC320 client with two FXO lines (ports 1, 2),which were recorded successfully. Within a few weeks, try to adda new line, which is not recorded in any of the remaining ports(3.4).
If exchange and put the new line in 1 or 2 ports, works perfectly.
Any idea how to fix this?
Thank you very much for your help.
Gonzalo
1 ACCEPTED SOLUTION
juliomar
Participant
Hi Gonzalo,
Please make sure that FXO3 and FXO4 are both enabled (checked) in the Ports and Trunks -> Line (FXO) Ports page of the UC320W Configuration utility.
If the ports are enabled, but fail to register the FXO trunk, please select to leave Feedback.  This will capture information from your device, and a support person can follow up with suggestions.
From your UC320W configuration utility on the upper right corner there is a cloud icon labeled Services, Select it and click on Feedback. Select Report Problems, enter the problem encountered, and an email address where we can reach you.
Best regards,
Julio
1 REPLY 1
juliomar
Participant
Hi Gonzalo,
Best regards,
Julio
