Problem with CCA 2.1 Locations
mrebelo
I am trying to configure an UC520 using the CCA2.1
I have downloaded the locale files as indicated by the "View Localization Instructions", and when I try to use the locale files in the Telephony Setup Wizard I don't find it. I have a reinstalled the cca and I do use the "reread installed languages" button.
Can anyone help me?
Miguel
Have you tried this again with CCA 2.2?
Marcos
I have the same issue with version 2.2, copied the files where I am instructed in the notes.
