05-20-2009 01:51 AM - last edited on 03-25-2019 10:36 PM by ciscomoderator
I have a customer who has a cisco 828 router delivered from his ISP. Behind that router I've connected the UC520 with a global IP adress. We are supposed to use a SIP trunk ftom a ITSP on the UC520 but are not able to get it up and running. I think it may be a NAT issue since the 828 is in front of the UC520. I'm not very good with NAT at all so any suggestions on how to make it work is appreciated.
Eivind
Solved! Go to Solution.
05-26-2009 12:24 PM
Hi Eivind,
PM stands for Private Message. You can send someone a message through the community by going to the "Your Stuff" button at the top of the page and clicking on "Private Messages." You can then send a message just like an email by typing in the member's username that you would like to send it to. You can check for private messages that have been sent to you by other members as well.
If you have any questions, please let me know.
Thank you,
Cisco Moderation Team
06-19-2009 01:31 AM
The 828 router had wrong config from SP
Eivind
