07-17-2010 04:06 PM - last edited on 03-25-2019 10:52 PM by ciscomoderator
Hello there colleagues!
I'm moving my business to an office (and out of the bedroom...!), but would like to be able to retain the capability of dialling out of my business phone lines from home. Without getting into configuration details which I can sort out later, I'm looking for a high level recommendation of the specific hardware that may do this job the best. I'm not looking for the most economical solution necessarily, but rather something that gives me the best combination of performance and value, leaning towards performance.
Here's what I've got going on:
07-17-2010 04:43 PM
HI Mac,
It would seem in this instance your 1811 is the core and everything you do will be centralized around it.
Possible Options:
I am sure others will have more options for you to look at, this is just what i would look at when planning it out.
Cheers,
David.
07-18-2010 11:57 AM
Thanks David - all great suggestions.
I like the CIPC idea, but it's not available for Mac (at least not for CME, for CM yes), and I'm Mac-based.
The 877W sounds good, but is only G wireless, and I'll be doing lots of media streaming so N is critical. The 891W actually has dual-band radios too, so that's an awesome bonus. I think the value in the 891W is amazing.
UC500 at home was an option, but don't have wireless in it, and if I add it, would only be G.
I'm leaning towards this option:
Office (voice segment of the network):
-UC520 on a public IP
Home:
-891W
-7925G
Anyone else vouch/vote for the setup above?
Thanks in advance for opinions/suggestions!
Luis
