Remote control of a door entrance
huberdeau
Is there a door access solution to use with the UC540?
David Hornstein
Level 7
Level 7
Check out the following link and work it from there;
https://www.myciscocommunity.com/docs/DOC-1514
There may be other products from Valcom as well.
regrads Dave
j.veltjen
you can use a vendor called cyberdata, they have ip based door systems that can integrate with the UC500/CCME
Best Regards,
Jerco
