Get the latest Cisco news in this February issue of the Cisco Small Business Monthly Newsletter
1159
Highlighted
Beginner
Remote phone with BE 6000
I am familiar with how to get a 7945/65 working remotely using SSL VPN & ASA on a CME.  I'm trying to put a BOM together for a BE 6000 system with remote VPN phones and I was wondering if BE 6000 handles this similarly?
Do I terminate the phones' vpn into the ASA or the VG (2921 in my case)?  Are there any documentation on this?  Thank you.
Everyone's tags (4)
3 REPLIES 3
Highlighted
Hall of Fame Cisco Employee
Not sure about the BOM, but in terms of how it works and how you configure it, it's the exact same thing on a standalone CUCM, and on a 6K CUCM.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Highlighted
Beginner
Thanks for the response.  The problem is that I'm coming from CME background and am not too familiar with doing this on a standalone CUCM or BE6K.  Any info or links to documents will be appreciated.
Highlighted
Since you don't mention the version, search "Communication Manager + security guide" on CCO and pick the one for your deployment, all the necessary info is there.
java
java
