Request for SIP-trunk Template Xconnection G729
Adriaan Mol
ParameterValue
Comment
Name of ITSP
Xconnection
G729
Enter name as you would like to see it in CCA drop down, please keep this as short as possible
Dialplan localenl(optional) provide the country locale if you know this
Display Proxy Server (Primary) fieldYesfield to enter IP address or DNS of ITSP's primary SIP proxy server
Display Proxy Server (Backup) fieldno(optional) field to enter IP address or DNS of ITSP's backup SIP proxy server
Display Registrar Server fieldyesfield to enter IP address or DNS of ITSP's SIP registrar server, this is required if ITSP requires SIP registrations
Display Outbound Proxy Server fieldNofield   to enter IP address or DNS of ITSP's Session Border Controller, this  is  required if ITSP has an SBC that is different compared to its proxy   server.
Display Digest Authentication (Username / Password)yesfield to enter username / password for SIP registration or calling, this is required if Registrar Server is present
Display Customer Company Name fieldNo(optional)  choose YES if specific caller name is required for outbound calls, usually ITSP does this
Display Call Admission Control fieldNo(optional) choose YES if ITSP requires the UC500 limit # of SIP calls, usually ITSP does this
Display User Credentials fieldYes
(optional)   choose YES if ITSP requires SIP registration of all DIDs associated to   the UC500 with a unique username / password per DID
ITSP SIP TRUNK PARAMETERS
Voice CodecG.729Choose one of the 3 codecs shown
Fax protocolG.711alawChoose one of the 2 methods - T.38 or G.711 upspeed
RFC2833 (DTMF) payload type101Default value is 101, if change is required, then enter value in range from 97 to 121
Should UC500 register all DIDs to ITSPYes
Typically most ITSPs register only the main number but if all numbers are required then choose YES
Is SIP registration for DID(s) using same username / password or unique username / password per DIDYes
Answer Yes or No only if above row is YES.
0 Replies 0
