08-10-2010 11:24 AM - edited 03-21-2019 02:50 AM
How do you reset the admin password on a cisco spa525g?
08-10-2010 12:00 PM
On the phone there is the Setup Button, then Device Administration; then I see "Factory reset", but that will be everything I would think....
09-13-2010 10:15 AM
Unfortunately, to get to "Reset to Factory Settings", I have to know the admin password. The original person is gone, so we need to completely start over. Is there a button or something? What do I do?
09-14-2010 08:14 AM
Dear Sir;
This is not possible. The whole reason for the password is to provide security. If factory reset is protected by password, then not possible to change/reset.
Alberto
09-27-2010 02:12 PM
This is not true... Try this.
Open a browser. Enter the following web address: http://IPAddress/admin/advanced
Where the IPAddress is the phone's IP.
This *should* let you into the interface without requiring you to enter any password information. You can then go to system configuration and strip out the user password. Submit the change and then you can factory reset the phone from the phone's interface.
Hope that helps. It worked for me using version 7.1.7.
Zach
01-23-2012 12:15 PM
While power cycling the SPA Phone, after you see the Cisco trademark symbol disappear and while it is going through it's animations, press the speaker button three times. That will reset the phone.
