Restrict FXO ports on the Outgoing Calls.
Mario Musquiz
I need to configure a restriction on the Outgoing Calls, i need the extension that start whit 1 (100,101,102,etc..) to only use the FXO ports 0/1/0  0/1/1  0/1/2 and the extensiones that start whit 2 (200,201,202,etc...) to only use the FXO ports 0/2/0  0/2/1  0/2/2, how can i make this happen ?
Darren DeCroock
Level 4
Level 4
Hello Mario,
First off, this is not possible with CCA, this can only be done though CLI.
1. Setup seperate PSTN Trunk Groups.  A: 0/1/0, 0/1/1, 0/1/2   B: 0/2/0, 0/2/1, 0/2/2
2. Setup Dial-Peers for each Trunk Group.
3. Setup COR list to restrict which users can use either Trunk Group.
That is the simple explaination, the actual setup can get quite complicated and lengthy.
Thank you,
Darren
