Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
286
ccmadm1n1
Beginner
route calls UC560 to/from CUCM 4.1
How do I setup a trunk between a CUCM 4.1(3) and a UC560
DID's come into The CUCM then need to come over to my UC560
Calls from UC660 need to go to through the CUCM and out the PRI
PRI is already working with CUCM via 6608 blades in a Cat 6500
This worked before with a UC520 that is now gone - replaced with this UC560.
The CUCM config is still in place - looks like h323 trunks were used and maybe SIP
Not sure what is needed on the UC560 config and doubt I will be done using CCA 3? CLI only?
0 REPLIES 0
Create
Recognize Your Peers
Polls
How would you describe your level of technical expertise?
