SCC Smart Call Connector NFR
alangoh27
I saw that NFR licences for SCC can be requested.
https://supportforums.cisco.com/docs/DOC-13287
Does anyone know how to get these?
David Trad
Hi Alan,
If you are the client then you need to ask your Cisco Partner to assist you with this (Be mindful that many don't like doing it as there is no coin in it for them )
Or if you are the partner, then speak with your Cisco Account Manager who will then get Authorization for you to get it at NFR pricing from the Distributor.
Cheers,
David Trad.
**If you don't want to rate a post that is fine, I'll just find out where you live and hunt you down**
^^ That's a joke just in case you didn't get it :)
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
