Screen Pops for UC500
ed.crawford
I have a customer that has a UC560 and would like to pop customer details on a screen based on the dialed number.  Does anyone know of anything that would be appropriate?
David Trad
Hi Ed,
Are you wanting a CRM solution that will work with the UC?
Can you clarify a little further about what it is exactly the client is after (Lost in terminology at the moment )
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
They have a CRM, they just want to be able to pop customer details to the screen when the call comes in.
