Set auto answer device in SIP header
gustavolsson
Beginner
Beginner
We have a scenario where we want the incoming calls with auto answer set to be routed to the headset, but paging calls (via multicast) should route to the speaker. Is there any way of acheiving this? If it's possible to specify output device to use for aa-calls in the SIP message, we could set default aa-device to speaker and then add the specific device (the headset) to be used by the aa-option in the SIP message? The setting we currently use for this is Preferred_Audio_Device and it seem to affect both paging calls and "normal" calls with auto answer.
0 Replies 0
