Announcement“Cisco Design Thinking Workshop”. Cisco Small Business is excited to invite its Silicon Valley customers to an exclusive interactive one-day session between customers and product Managers.  If you are interested in this exclusive workshop, please fill out the Registration Form. For more information, please check out our FAQ
Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
182
Set Call Forwarding on and off on line Extension Keys.
is it possible to enable and disable call Forwarding to a specific number with only one line key ?
So wenn you press the line key 1 it calls *72005723864455 and the line key turns red while call forwarding is enabled, when you press it again it disables call forwarding and the line key turns green.
It´s possible to enable call forwarding on line Key 1 and disable it on line key 2, the problem with that solution is that the User of the Phone does not now if Call forwarding  is enabled or not.
So is there a solution where line key 1 turns red when enabling Forwarding and the turns green again when disabling it with line key 2 ?
Greetings
Florian
Florian
3 REPLIES 3
Advocate
Re: Set Call Forwarding on and off on line Extension Keys.
Line Key can have two predefined sequences to dial. It alternates between them. But it's just dumb flip-flop mechanism, no feedback. Thus key state may not be synchronised with the PBX state. I dislike it, but you may consider it acceptable.
Or, if you PBX is smart/configurable enough, you may dial just single sequence - it's up to PBX to turn forwarding on if it has been off and vice versa.
It depends. Line key color can be linked with a state provider (SIP SUBSCRIBE method). It's intended to be used as Busy Lamp, but it can display any state published by PBX. Our PBX publishes state of many supplemental services, so I can link a line key not only to state of CFU, but also other flavors of forwarding services, to DND service and many others. So answer to your question depends on features of the PBX you are using
Thanks for your quick and thorough answer, i completely forgot to mention that wer are using SPA504G Phones, but i guess that does not change anything about your answer as you stated it all depends on the pbx we are using.
Advocate
We are in Small Business Support Community part of Cisco Community so I assumed SMB phones like SPA3xx or SPA5xx.
One more note - Line key can be configured to invoke internal "browser" - you can request remote page and do something with response (it's not standard HTML but CIsco's custom XML-like format instead). It allows you to craft complex extensions to phone UI according your requirements. Even this solution depends on (API of) PBX you have.
