Get
the latest new and information the November issue of the Cisco
Small
Business Monthly Newsletter
Is it possible to run a SF 200-24P switch on a UC560 thru the expansion port?
I already have a SF 200-24P and I am trying to avoid buying another switch?
Anyone have a document or knowledge of this?
Keith
Solved! Go to Solution.
Hello Keith,
Yes it is possible. You need to switch the port to trunk or change the smartport role.
In CCA also it is very easy. The switch is supported in CCA also. You may check the CCA (3.2.1) admin guide:
http://www.cisco.com/c/dam/en/us/td/docs/net_mgmt/cisco_configuration_assistant/version3_2_1/administration_guide/cca_sbcs_admin_guide.pdf
HTH,
Alex
*Please rate helpful posts
Hello Keith,
HTH,
Alex
