Get the latest Cisco news in this December issue of the Cisco Small Business Monthly Newsletter
372
Highlighted
Beginner
Show which FXO Line is Called with UC540 and SP-50x
is this possible to show? so my customer can see for example line 3 is called (which is the private line) and take the call....?
Thanks!
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Show which FXO Line is Called with UC540 and SP-50x
You can assign a CO Line button to the phone for that line. When it's called it turns red and you should be able to pick it up. You should also be able to press it when it's off to seize the line and place a call
1 REPLY 1
