01-24-2011 08:14 AM - edited 03-21-2019 03:34 AM
All,
I have set up single number reach (also tried adding an external number to a blast group) and everything works fin when I dial in through the SIP trunk (PSTN calls teh external number). However when calling the PSTN number (Only 1 line), the external number is not reached through the SIP trunk. Outbound dialing through the SIP trunk works fine. Any thoughts? Configuration below.
Thanks for your help!
-John
BC_VOIP_01#sh run
Building configuration...
Current configuration : 37308 bytes
! Last configuration change at 21:11:29 EST Sat Jan 22 2011 by administrator
version 12.4
parser config cache interface
no service pad
no service timestamps debug uptime
service internal
service compress-config
service sequence-numbers
hostname BC_VOIP_01
boot-start-marker
boot system flash uc500-advipservicesk9-mz.124-20.T2(2).bin
boot-end-marker
logging message-counter syslog
no logging buffered
no logging rate-limit
enable secret 5 $1$hcEO$dg2IewFQdqWycHDccuz8a/
aaa new-model
aaa session-id common
clock timezone EST -5
clock summer-time EDT recurring
crypto pki trustpoint TP-self-signed-2006719407
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2006719407
revocation-check none
rsakeypair TP-self-signed-2006719407
crypto pki certificate chain TP-self-signed-2006719407
certificate self-signed 01
dot11 syslog
dot11 ssid cisco-data
vlan 1
authentication open
dot11 ssid cisco-voice
vlan 100
authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.10.1 192.168.10.9
ip dhcp excluded-address 192.168.10.241 192.168.10.255
ip dhcp excluded-address 192.168.5.241 192.168.5.255
ip dhcp excluded-address 192.168.5.1 192.168.5.9
ip dhcp pool phone
network 192.168.5.0 255.255.255.0
default-router 192.168.5.1
option 150 ip 192.168.5.1
ip dhcp pool data
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 192.168.0.3
ip domain name bcnet.com
ip name-server 192.168.0.3
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol none
no fax-relay sg3-to-g3
sip
registrar server expires max 3600 min 3600
localhost dns:bcnet.com
no update-callerid
sip-profiles 1000
voice class codec 1
codec preference 1 g729r8
voice class sip-profiles 1000
request ANY sdp-header Connection-Info remove
response ANY sdp-header Connection-Info remove
voice class cause-code 1
no-circuit
voice register global
max-dn 56
max-pool 14
voice hunt-group 1 parallel
final 199
list 102,103,101
timeout 16
pilot 111
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 1
translation-profile incoming SIP_Incoming
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 2
voice translation-rule 4
rule 1 /16179399004/ /111/
voice translation-rule 410
rule 1 /^9\(.*\)/ /\1/
rule 15 /^...$/ /99051000127350/
voice translation-rule 411
rule 1 /^9\(.*\)/ /ABCD9\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile DID-SIP-BG_Called_4
translate called 4
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
fax interface-type fax-mail
username administrator privilege 15 secret 5 *******
archive
log config
logging enable
logging size 600
hidekeys
ip tftp source-interface Loopback0
bridge irb
interface Loopback0
ip address 10.1.10.2 255.255.255.252
ip virtual-reassembly
interface FastEthernet0/0
ip address 192.168.0.254 255.255.255.0
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface Dot11Radio0/5/0
no ip address
shutdown
ssid cisco-data
ssid cisco-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
antenna receive right
antenna transmit right
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip address 192.168.10.1 255.255.255.0
interface BVI100
ip address 192.168.5.1 255.255.255.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
access-list 1 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 1 remark SDM_ACL Category=1
access-list 1 permit 192.168.10.1
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 192.168.5.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 63.209.144.201
access-list 2 deny any
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 192.168.10.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-4-4.bin alias spa525g-7-4-4.bin
tftp-server flash:/phones/5x5/spa5x5-7-4-4.bin alias spa5x5-7-4-4.bin
tftp-server flash:/phones/7906_7911/apps11.8-5-3TH1-6.sbn alias apps11.8-5-3TH1- 6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-3TH1-6.sbn alias cnu11.8-5-3TH1-6. sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-3TH1-6.sbn alias cvm11sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-3TH1-6.sbn alias dsp11.8-5-3TH1-6. sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-3TH1-6.sbn alias jar11sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-3S.loads alias SCCP11.8-5-3S.load s
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.lo ads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.lo ads
tftp-server flash:/phones/7914/S00105000400.sbn alias S00105000400.sbn
tftp-server flash:/phones/7915/B015-1-0-4.SBN alias B015-1-0-4.SBN
tftp-server flash:/phones/7916/B016-1-0-4.SBN alias B016-1-0-4.SBN
tftp-server flash:/phones/7921/APPS-1.3.4SR1.SBN alias APPS-1.3.4SR1.SBN
tftp-server flash:/phones/7921/CP7921G-1.3.4SR1.LOADS alias CP7921G-1.3.4SR1.LOA DS
tftp-server flash:/phones/7921/GUI-1.3.4SR1.SBN alias GUI-1.3.4SR1.SBN
tftp-server flash:/phones/7921/MISC-1.3.4SR1.SBN alias MISC-1.3.4SR1.SBN
tftp-server flash:/phones/7921/SYS-1.3.4SR1.SBN alias SYS-1.3.4SR1.SBN
tftp-server flash:/phones/7921/TNUX-1.3.4SR1.SBN alias TNUX-1.3.4SR1.SBN
tftp-server flash:/phones/7921/WLAN-1.3.4SR1.SBN alias WLAN-1.3.4SR1.SBN
tftp-server flash:/phones/7925/APPSH-1.3.4SR1.SBN alias APPSH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/CP7925G-1.3.4SR1.LOADS alias CP7925G-1.3.4SR1.LOA DS
tftp-server flash:/phones/7925/GUIH-1.3.4SR1.SBN alias GUIH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/MISCH-1.3.4SR1.SBN alias MISCH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/SYSH-1.3.4SR1.SBN alias SYSH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/TNUXH-1.3.4SR1.SBN alias TNUXH-1.3.4SR1.SBN
tftp-server flash:/phones/7925/WLANH-1.3.4SR1.SBN alias WLANH-1.3.4SR1.SBN
tftp-server flash:/phones/7931/apps31.8-5-3TH1-6.sbn alias apps31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/cnu31.8-5-3TH1-6.sbn alias cnu31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/cvm31sccp.8-5-3TH1-6.sbn alias cvm31sccp.8-5-3TH1 -6.sbn
tftp-server flash:/phones/7931/dsp31.8-5-3TH1-6.sbn alias dsp31.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/jar31sccp.8-5-3TH1-6.sbn alias jar31sccp.8-5-3TH1 -6.sbn
tftp-server flash:/phones/7931/SCCP31.8-5-3S.loads alias SCCP31.8-5-3S.loads
tftp-server flash:/phones/7931/term31.default.loads alias term31.default.loads
tftp-server flash:/phones/7936/cmterm_7936.3-3-20-0.bin alias cmterm_7936.3-3-20 -0.bin
tftp-server flash:/phones/7937/apps37sccp.1-3-4-0.bin alias apps37sccp.1-3-4-0.b in
tftp-server flash:/phones/7940_7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phones/7940_7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phones/7940_7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phones/7940_7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phones/7941_7961/apps41.8-5-3TH1-6.sbn alias apps41.8-5-3TH1- 6.sbn
tftp-server flash:/phones/7941_7961/cnu41.8-5-3TH1-6.sbn alias cnu41.8-5-3TH1-6. sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-5-3TH1-6.sbn alias cvm41sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-5-3TH1-6.sbn alias dsp41.8-5-3TH1-6. sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-5-3TH1-6.sbn alias jar41sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-5-3S.loads alias SCCP41.8-5-3S.load s
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.lo ads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.lo ads
tftp-server flash:/phones/7942_7962/apps42.8-5-3TH1-6.sbn alias apps42.8-5-3TH1- 6.sbn
tftp-server flash:/phones/7942_7962/cnu42.8-5-3TH1-6.sbn alias cnu42.8-5-3TH1-6. sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-5-3TH1-6.sbn alias cvm42sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7942_7962/dsp42.8-5-3TH1-6.sbn alias dsp42.8-5-3TH1-6. sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-5-3TH1-6.sbn alias jar42sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-5-3S.loads alias SCCP42.8-5-3S.load s
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.lo ads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.lo ads
tftp-server flash:/phones/7945_7965/apps45.8-5-3TH1-6.sbn alias apps45.8-5-3TH1- 6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-3TH1-6.sbn alias cnu45.8-5-3TH1-6. sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-3TH1-6.sbn alias cvm45sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-3TH1-6.sbn alias dsp45.8-5-3TH1-6. sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-3TH1-6.sbn alias jar45sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-3S.loads alias SCCP45.8-5-3S.load s
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.lo ads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.lo ads
tftp-server flash:/phones/7970_7971/apps70.8-5-3TH1-6.sbn alias apps70.8-5-3TH1- 6.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-5-3TH1-6.sbn alias cnu70.8-5-3TH1-6. sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-5-3TH1-6.sbn alias cvm70sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-5-3TH1-6.sbn alias dsp70.8-5-3TH1-6. sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-5-3TH1-6.sbn alias jar70sccp.8-5 -3TH1-6.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-5-3S.loads alias SCCP70.8-5-3S.load s
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.lo ads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.lo ads
tftp-server flash:/phones/7975/apps75.8-5-3TH1-6.sbn alias apps75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cnu75.8-5-3TH1-6.sbn alias cnu75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/cvm75sccp.8-5-3TH1-6.sbn alias cvm75sccp.8-5-3TH1 -6.sbn
tftp-server flash:/phones/7975/dsp75.8-5-3TH1-6.sbn alias dsp75.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/jar75sccp.8-5-3TH1-6.sbn alias jar75sccp.8-5-3TH1 -6.sbn
tftp-server flash:/phones/7975/SCCP75.8-5-3S.loads alias SCCP75.8-5-3S.loads
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.x ml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsb usy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidopt ion.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_h old.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_men u.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_o perator.au
tftp-server flash:/Desktops/320x212x12/TN-BCNET.png
tftp-server flash:/Desktops/320x212x12/BCNET.png
tftp-server flash:/ringtones/CTU.raw alias CTU.raw
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
station-id number 101
caller-id enable
voice-port 0/0/1
shutdown
caller-id enable
voice-port 0/0/2
shutdown
caller-id enable
voice-port 0/0/3
shutdown
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 111
description Configured by CCA 4 FXO-0/1/0-BG
caller-id enable
voice-port 0/1/1
connection plar 202
shutdown
caller-id enable
voice-port 0/1/2
connection plar 203
shutdown
caller-id enable
voice-port 0/1/3
connection plar 204
shutdown
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 192.168.5.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register mtp001d706e6280
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk Skype for SIP
codec g711ulaw
codec g729abr8
codec g729ar8
maximum sessions 6
associate application SCCP
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
name PSTN-fax
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list call-fax
member PSTN-fax
dial-peer voice 1 pots
destination-pattern 101
port 0/0/0
no sip-register
dial-peer voice 2 pots
port 0/0/1
no sip-register
dial-peer voice 3 pots
port 0/0/2
no sip-register
dial-peer voice 4 pots
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description catch all dial peer for BRI/PRI^T
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 199
b2bua
voice-class sip outbound-proxy ipv4:10.1.10.1
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-7-digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-7-digit*International**
preference 5
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-7-digit*Toll-Free**
preference 5
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91877.......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91855.......
forward-digits all
no sip-register
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (Skype for SIP) **
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session target sip-server
dtmf-relay rtp-nte
ip qos dscp cs3 signaling
no vad
dial-peer voice 1001 voip
corlist outgoing call-local
description ** star code to SIP trunk (Skype for SIP) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound MWI from CUE **
b2bua
incoming called-number A80T
codec g711ulaw
no vad
dial-peer voice 1020 voip
translation-profile outgoing PSTN_Outgoing
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1021 voip
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1022 voip
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1023 voip
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1024 voip
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1025 voip
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1026 voip
description **CCA*North American-7-digit*Service Numbers**
preference 6
destination-pattern 9[2-9]11
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1027 voip
description **CCA*North American-7-digit*7-Digit Local**
preference 6
destination-pattern 9[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1028 voip
corlist outgoing call-national
description **CCA*North American-7-digit*Long Distance**
preference 6
destination-pattern 91[2-9]..[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3000 voip
description DID-SIP-BG
translation-profile incoming DID-SIP-BG_Called_4
voice-class codec 1
incoming called-number 16179399004
dtmf-relay rtp-nte
no vad
dial-peer voice 60 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
no dial-peer outbound status-check pots
sip-ua
credentials username 99051000127350 password 7 ******
realm sip.skype.com
authentication username 99051000127350 password 7 ******* C
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:sip.skype.com expires 3600
sip-server dns:sip.skype.com
connection-reuse
host-registrar
g729-annexb override
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 6
sdspfarm tag 2 mtp001d706e6280
video
fxo hook-flash
load 7914 S00105000400
load 7915-12 B015-1-0-4
load 7915-24 B015-1-0-4
load 7916-12 B016-1-0-4
load 7916-24 B016-1-0-4
load 7906 SCCP11.8-5-3S
load 7911 SCCP11.8-5-3S
load 7921 CP7921G-1.3.4SR1
load 7925 CP7925G-1.3.4SR1
load 7931 SCCP31.8-5-3S
load 7936 cmterm_7936.3-3-20-0
load 7937 apps37sccp.1-3-4-0
load 7960-7940 P00308010200
load 7941 SCCP41.8-5-3S
load 7941GE SCCP41.8-5-3S
load 7942 SCCP42.8-5-3S
load 7945 SCCP45.8-5-3S
load 7961 SCCP41.8-5-3S
load 7961GE SCCP41.8-5-3S
load 7962 SCCP42.8-5-3S
load 7965 SCCP45.8-5-3S
load 7970 SCCP70.8-5-3S
load 7971 SCCP70.8-5-3S
load 7975 SCCP75.8-5-3S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-4
max-ephones 14
max-dn 56
ip source-address 192.168.5.1 port 2000
auto assign 1 to 1 type bri
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message BCNET
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
time-zone 12
keepalive 30 auxiliary 4
voicemail 199
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 ******
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
fac standard
create cnf-files version-stamp 7960 Jan 19 2011 21:37:33
ephone-template 15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template 16
ephone-template 17
softkeys remote-in-use CBarge Newcall
ephone-template 18
ephone-dn 1
number 123 no-reg primary
description IP-Paging1
name AllApartment
paging ip 239.1.1.1 port 2000
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn 12 dual-line
number 203 no-reg primary
label 203
description 203
name 203
ephone-dn 13 dual-line
number 204 no-reg primary
label 204
description 204
name 204
ephone-dn 14 dual-line
number 205 no-reg primary
label 205
description 205
name 205
ephone-dn 15 dual-line
number 206 no-reg primary
label 206
description 206
name 206
ephone-dn 16 dual-line
number 207 no-reg primary
label 207
description 207
name 207
ephone-dn 17 dual-line
number 208 no-reg primary
label 208
description 208
name 208
ephone-dn 18 dual-line
number 209 no-reg primary
label 209
description 209
name 209
ephone-dn 19 dual-line
number 210 no-reg primary
label 210
description 210
name 210
ephone-dn 52 octo-line
number 103 no-reg primary
label 103
description Bedroom Desk
name Bedroom Desk
call-forward busy 199
call-forward noan 199 timeout 20
ephone-dn 53 dual-line
number 102 no-reg primary
label 102
description Movie Theater
name Movie Theater
ephone-dn 54
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 199
ephone-dn 55
number A801... no-reg primary
mwi off
ephone-dn 56
number A800... no-reg primary
mwi on
ephone 5
device-security-mode none
mac-address 0016.C7AE.DF2A
ephone-template 16
username "MTheater" password 123456
paging-dn 1
type 7970
button 1:53
ephone 6
video
mac-address 0014.A892.5405
ephone-template 16
username "BDesk" password 123456
speed-dial 1 91********* label "NOC HOTLINE"
type 7970
button 1:52
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.0. Mon Ja n 17 19:08:01 EST 2011^^C
alias exec cca_voice_mode PBX
alias exec cca_vm_notification schedule from_time=00 to_time=24
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
end
Solved! Go to Solution.
01-31-2011 07:40 AM
John,
Changing these things should fix the issue.
translate calling 1111 <--- Add rule for caller ID.
rule 15 /.*/ /99051000127350/ <--- Match all outbound calls.
CLI:
conf t
exit
end
write mem
Just remember that one effect of this will be that all outbound calls for SNR, or call forward will look like they are coming from the UC500, and not the actual calling party.
Note: This is not compatible with CCA, and changing the outgoing, or incoming dial plan may overwrite these settings
Thank you,
Darren
01-24-2011 04:19 PM
Hi John,
Check with Skype to see if they support CLIP (calling line identification presentation).
You may also want to upgrade to a newer software package. There are issues with one way audio on hairpin calls using SIP.
-Mario
01-26-2011 06:31 AM
I used SNR with SIP Skype before fine.
They only funny I had was the single number reach number had to be the full international number i.e international access code + country code + number
01-26-2011 11:26 PM
Can you provide the topology of your network from UC to SIP carrier. It looks like you are double nat.
01-29-2011 10:05 AM
Thanks for your replies,
I have upgraded to the newest IOS and after digging in the issue seems to be the following (maybe CLIP):
Skype requires that the caller ID outbound is the account number, when the blast group or sinlge number reach is configured, the UC500 puts the true caller ID in the SIP invite and Skype for Sip rejects it as it doesn't match the account number. In the UC500 under the outgoing dial plan I have hardset the caller ID to the account number for the SIP trunk.
However it seems like its not catching.
Thanks!
John
01-29-2011 01:26 PM
John,
Can you post your update config?
Mario
01-30-2011 06:11 PM
BC_VOIP_01#sh run
Current configuration : 37227 bytes
! Last configuration change at 21:01:43 EST Sun Jan 30 2011 by administrator
! NVRAM config last updated at 21:01:40 EST Sun Jan 30 2011 by administrator
version 12.4
no service pad
service internal
hostname BC_VOIP_01
boot-start-marker
boot system flash uc500-advipservicesk9-mz.124-22.YB8.bin
boot-end-marker
no logging buffered
enable secret 5
aaa new-model
quit
dot11 syslog
vlan 1
authentication open
vlan 100
authentication open
ip source-route
ip cef
ip dhcp pool phone
domain-name bcnet.com
ip dhcp pool data
import all
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
voice rtp send-recv
voice service voip
fax protocol none
sip
no update-callerid
voice class codec 1
no-circuit
max-dn 56
max-pool 14
final 199
list 102,103,101,912015230537,104
timeout 16
pilot 111
access-list 1
access-list 2
rule 1 /.*/ //
rule 1 /^9/ //
rule 1 /^6/ //
translate called 4
voice-card 0
dspfarm
archive
log config
logging enable
logging size 600
hidekeys
bridge irb
interface Loopback0
load-interval 30
duplex auto
speed auto
no ip address
shutdown
ssid cisco-data
ssid cisco-voice
station-role root
bridge-group 1
bridge-group 100
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
interface BVI100
ip http server
ip dns server
access-list 2 permit 204.9.161.164
tftp-server flash:/phones/7906_7911/apps11.8-5-3TH1-6.sbn alias apps11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cnu11.8-5-3TH1-6.sbn alias cnu11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.8-5-3TH1-6.sbn alias cvm11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/dsp11.8-5-3TH1-6.sbn alias dsp11.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.8-5-3TH1-6.sbn alias jar11sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7906_7911/SCCP11.8-5-3S.loads alias SCCP11.8-5-3S.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7921/CP7921G-1.3.4SR1.LOADS alias CP7921G-1.3.4SR1.LOADS
tftp-server flash:/phones/7925/CP7925G-1.3.4SR1.LOADS alias CP7925G-1.3.4SR1.LOADS
tftp-server flash:/phones/7931/cvm31sccp.8-5-3TH1-6.sbn alias cvm31sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7931/jar31sccp.8-5-3TH1-6.sbn alias jar31sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7936/cmterm_7936.3-3-20-0.bin alias cmterm_7936.3-3-20-0.bin
tftp-server flash:/phones/7937/apps37sccp.1-3-4-0.bin alias apps37sccp.1-3-4-0.bin
tftp-server flash:/phones/7941_7961/apps41.8-5-3TH1-6.sbn alias apps41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/cnu41.8-5-3TH1-6.sbn alias cnu41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.8-5-3TH1-6.sbn alias cvm41sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/dsp41.8-5-3TH1-6.sbn alias dsp41.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.8-5-3TH1-6.sbn alias jar41sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7941_7961/SCCP41.8-5-3S.loads alias SCCP41.8-5-3S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7942_7962/apps42.8-5-3TH1-6.sbn alias apps42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/cnu42.8-5-3TH1-6.sbn alias cnu42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.8-5-3TH1-6.sbn alias cvm42sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/dsp42.8-5-3TH1-6.sbn alias dsp42.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.8-5-3TH1-6.sbn alias jar42sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7942_7962/SCCP42.8-5-3S.loads alias SCCP42.8-5-3S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7945_7965/apps45.8-5-3TH1-6.sbn alias apps45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/cnu45.8-5-3TH1-6.sbn alias cnu45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.8-5-3TH1-6.sbn alias cvm45sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/dsp45.8-5-3TH1-6.sbn alias dsp45.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.8-5-3TH1-6.sbn alias jar45sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7945_7965/SCCP45.8-5-3S.loads alias SCCP45.8-5-3S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7970_7971/apps70.8-5-3TH1-6.sbn alias apps70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-5-3TH1-6.sbn alias cnu70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-5-3TH1-6.sbn alias cvm70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-5-3TH1-6.sbn alias dsp70.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-5-3TH1-6.sbn alias jar70sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-5-3S.loads alias SCCP70.8-5-3S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7975/cvm75sccp.8-5-3TH1-6.sbn alias cvm75sccp.8-5-3TH1-6.sbn
tftp-server flash:/phones/7975/jar75sccp.8-5-3TH1-6.sbn alias jar75sccp.8-5-3TH1-6.sbn
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
station-id name Cordless
caller-id enable
voice-port 0/0/1
station-id name ABORT
station-id number 104
caller-id enable
voice-port 0/0/2
shutdown
caller-id enable
voice-port 0/0/3
shutdown
caller-id enable
voice-port 0/1/0
caller-id enable
voice-port 0/1/1
trunk-group ALL_FXO 63
connection plar 202
shutdown
caller-id enable
voice-port 0/1/2
trunk-group ALL_FXO 62
connection plar 203
shutdown
caller-id enable
voice-port 0/1/3
trunk-group ALL_FXO 61
connection plar 204
shutdown
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
sccp
sccp ccm group 1
codec g711ulaw
codec g729abr8
codec g729ar8
maximum sessions 6
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
name PSTN-fax
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member emergency
member internal
member local
member emergency
member toll-free
member internal
member local
member local-plus
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member PSTN-fax
port 0/0/0
no sip-register
destination-pattern 104
port 0/0/1
no sip-register
port 0/0/2
no sip-register
port 0/0/3
no sip-register
port 0/4/0
no sip-register
direct-inward-dial
port 0/1/0
port 0/1/1
port 0/1/2
port 0/1/3
port 0/1/0
no sip-register
port 0/1/1
no sip-register
port 0/1/2
no sip-register
port 0/1/3
no sip-register
b2bua
codec g711ulaw
no vad
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
permission term
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
b2bua
codec g711ulaw
no vad
b2bua
codec g711ulaw
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 6
voice-class codec 1
dtmf-relay rtp-nte
no vad
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
sip-ua
credentials username 99051000127350 password 7 **** realm sip.skype.com
no remote-party-id
retry invite 2
retry register 10
timers connect 100
connection-reuse
host-registrar
telephony-service
sdspfarm units 5
video
em logout 0:0 0:0 0:0
fxo hook-flash
max-ephones 14
max-dn 56
url idle http://192.168.2.4/V2/Idle/idle.php idle-timeout 1
time-zone 12
voicemail 199
web admin system name cisco secret 5 $1$LueE$BYPOgzzgSJk4ep/WZBDMN0
dn-webedit
time-webedit
transfer-pattern .T
fac standard
create cnf-files version-stamp 7960 Jan 30 2011 21:01:36
ephone-template 15
ephone-template 16
ephone-template 17
ephone-template 18
ephone-dn 1
name AllApartment
ephone-dn 9
description MoH
moh out-call ABC
label 203
description 203
name 203
label 204
description 204
name 204
label 205
description 205
name 205
label 206
description 206
name 206
label 207
description 207
name 207
label 208
description 208
name 208
label 209
description 209
name 209
label 210
description 210
name 210
label 103
name Bedroom Desk
label 102
name Movie Theater
ephone-dn 54
ephone-dn 55
mwi off
ephone-dn 56
mwi on
ephone 5
video
ephone-template 16
paging-dn 1
type 7970
button 1:53
ephone 6
video
ephone-template 16
speed-dial 1 9******** label "NOC HOTLINE"
paging-dn 1
type 7970
button 1:52
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.0. Mon Jan 17 19:08:01 EST 2011^^C
line con 0
no modem enable
line aux 0
line 2
no exec
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
end
01-31-2011 07:40 AM
John,
CLI:
conf t
exit
end
write mem
Thank you,
Darren
