SIP CONFIGURATION
avmega
My sip provider (ITSP), witch is the main sip provider in Portugal  uses de following configuration:
Proxy:  proxy.voip.sapo.pt
Proxy Port:  5070
Registar:  voip.sapo.pt
Registar Port:  5060
Usetname: +351XXXXXXXXX
Password: XXXXXXXX
Since i cannot specify ports in cca i can´t make this work
Is there a way to configure this in my cisco uc560 ?
I also thing that it should be possible configure ports in sip trunking in cca
John Platts
Level 4
Level 4
I do know that IOS and CME already has the capability to use non-standard SIP ports for registrar and SIP proxy. However, this problem should really be fixed in CCA, even though the problem can be worked around by configuring the dialplan and SIP trunking in CLI.
