03-13-2015 03:13 AM - edited 03-21-2019 08:34 AM
i have a UC 500 connected to our phone provider using a SIP trunk.
All the phones are SPA508 G
All is working fine !
Then, some days ago i added a SIP phone (extention 350) on the UC500, that also worked fine, and then after some minutes all our incoming/outgoing calls were blocked.
I called my provider that told me that our IP was banned because they have seen to much registration attempt from a bad user that was "350"
I can confirm with a "sh sip-ua register status" command that i had two sip registration : my SIP trunk and the SIP phone
Then it seems that the UC 500 is trying to register the SIP phone on the SIP trunk ?
What am i doing wrong ?
Is there a command to avoid that ?
Bellow is how the SIP phone and the SIP trunk are configured
Many thanks for your help, i was unable to find anything about that, but i guess somebody already had this problem !
The SIP phone -------------------------------------------------------------------------
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol none
modem passthrough nse codec g711ulaw
sip
registrar server expires max 3600 min 120
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 20
max-pool 20
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
load 7971 term71.default
authenticate register
authenticate realm xxxxxx.com
timezone 13
hold-alert
mwi stutter
mwi reg-e164
create profile sync 0636240803635305
voice register dn 1
number 350
name Conference
label Conference
voice register pool 1
id mac 1234.1234.1234
number 1 dn 1
username 350 password 1234
codec g711ulaw
The SIP trunk ----------------------------------------------------------------------
sip-ua
credentials username user1234 password 1234 realm sipgw9.provider.com
authentication username user1234 password 1234 no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar dns:sipgw9.provider.com expires 3600
sip-server dns:sipgw9.provider.com
Solved! Go to Solution.
04-02-2015 12:10 PM
I would recommend that you disable the sip outbound-proxy under voice register global.
Under "sip" configuration, your timers doesn't appear to be by the book (registrar server expires max 3600 min 120). It should be "registrar server expires max 600 min 60", because you already specify the expires timer under the user-agent to 3600.
Is the phone registered correctly?
Check this document (http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_phreg.html#wp1054191). In case your problem persists, please add some debugs.
FT
04-13-2015 02:08 PM
03-17-2015 02:41 AM
No idea ?
Is there something i did explain badly ?
Do you need more info ?
03-17-2015 07:49 AM
I'm still searching on the forum, and maybe i found somthing related to my problem, not sure... any advice ?
Disable outbound proxy on voice register global as by default it will use the outbound proxy configured on the system which would not make sense
no outbound-proxy
found there : https://supportforums.cisco.com/discussion/10760741/uc500-sip-server-and-sip-trunk
03-24-2015 06:20 AM
really, nobody can help me with that ?
thanks
03-17-2015 07:49 AM
Reply error
04-22-2015 08:29 AM
Ok, some news.
I went to the customer and first tried the "no-reg" solution under each "voice register dn". That was no enought and then i applied the second solution "voice register global - no outbound-proxy"
I'm using command "sh sip-ua register status"
From that i had still 2 extention that was still registering, and they were configured exactly as the other... really weird ! I just reloaded the uc500 and all was then ok.
I had another problem : my secondary extention into my ephone-dn were also registering !!!
I had
ephone-dn 1
number 123 secondary 0123456789 no-reg primary
Then extentions 0123456789 were trying to register also
i had to put everywhere :
number 123 secondary 0123456789 no-reg both
I hope this won't be a problem...
And then only my sip trunk was registering !
Thanks you for your help
04-02-2015 06:00 AM
A little UP, please ?
04-02-2015 12:10 PM
FT
04-03-2015 12:02 AM
Hi Filipe,
thanks so much for this reply !
This confirm what i found (please see two posts bellow, in blue) and i'll try that.
I'll have to go to my Customer to test that next week or the following.
My provider is able to "white list" my IP during my test. If there is any problem i'll collect debugs.
If this is ok, i'll mark as "correct answer".
many thanks
edit : sorry i forgot to reply to your question; yes the phone is correctly registered, i can call and be called, no problem. The only problem is the registration to the phone provider.
04-04-2015 09:22 AM
Hi impi,
No problem at all, i'm just here to help.
You can also under the sip configuration bind the signalling and media interface:
sip
bind control source-interface INTERFACE
bind media source-interface INTERFACE
Or
bind all source-interface INTERFACE
Or you can specify it under the dial-peer side.
Please check this link for further explanation (http://www.cisco.com/c/en/us/td/docs/ios/voice/sip/configuration/guide/15_0/sip_15_0_book/sip_cg-bind.html)
Please rate if helpful.
04-13-2015 02:08 PM
try:
voice register dn 1
no-reg
/Adam
04-13-2015 11:48 PM
Many thanks for that Adam, this looks like a good idea !
I'll try and tell you (i guess next week)
regards
04-14-2015 10:17 AM
Sure.
