1404
Highlighted
SIP Trunk Between UC560 and Asterisk
Good morning
I need to configure a SIP trunk between a UC560 and Asterisk.
I have already set up the Asterisk Trunk, routes incoming and outgoing calls.
At the moment all SIP calls proventienti dall'Asterisk and directed to the UC560 work regularly.
I have some problems on calls from dall'UC560 directed to Asterisk.
UC tells me that "The Number you have dialed is not in service"
I have enabled debugging on Asterisk SIP and I noticed the following:
     pbxpi * CLI>
     <--- SIP read from UDP :/ / 192.168.0.227:57446 --->
     ACK sip: 701@192.168.0.230: 5060 SIP/2.0
     Via: SIP/2.0/UDP 192.168.0.227:5060; branch = z9hG4bK57231F
     From: "UC Extension" <sip:311@192.168.0.230>; tag = 1F7C8C-16B
     To: <sip:801@192.168.0.230>; tag = as707a2df5
     Date: Fri, 21 Apr 2013 07:39:38 GMT
     Call-ID: 8F6EE81A-D97C11E2-8065DF0E-CD1EB93@192.168.35.227
     Max-Forwards: 70
     CSeq: 101 ACK
     Allow-Events: telephone-event
     Content-Length: 0
The problem seems to be that, typing 801 on a phone connected to the UC560 the "To" field contains "@192.168.0.230" (which is the IP address of the UC)
Unlike a SIP call made ​​by a PC connected to UC560 with SotPhone attested to Asterisk I note the following:
     <--- SIP read from UDP :/ / 192.168.10.12:5070 --->
     ACK sip: SIP/2.0 301@192.168.0.230
     Via: SIP/2.0/UDP 192.168.10.12:5070; rport; branch = z9hG4bK2932784
     To: <sip:301@192.168.0.230>; tag = as59a60f05
     From: "SoftPhone" <sip:701@192.168.0.230>; tag = 7185
     Call-ID: 1371751226-2784-COMPUTER-NAME@5.98.211.178
     CSeq: 457 ACK
     Max-Forwards: 20
     User-Agent: NCH Software Express Talk 4.28
     Authorization: Digest
     Content-Length: 0
The Field "To" is properly compiled!!! Can you give me some guidance to solve the problem?
Thank you very much in advance
1 ACCEPTED SOLUTION
Highlighted
Under sip-ua, configure sip-server with the 3rd party address, not the UC address.
Also registrar (if used) should be another system address, not local.
5 REPLIES 5
Highlighted
Hall of Fame Master
Post UC500 configuration.
Highlighted
Sure!
Highlighted
Highlighted
Thanks a Lot!
Highlighted
Thank you for the nice rating and good luck!
