07-07-2014 03:10 AM - edited 03-21-2019 08:18 AM
Hi Community.
I setup SIP Trunk with the CCA. Everything is working Call In and Call Out. Call Forward and so on.
But with Single Number reach is something wrong. The mobile phone is ringing and I can get the call, but I hear not any voice.
Can someone please help me out? Below the config.
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
dot11 ssid cisco-data
vlan 1
authentication open
dot11 ssid cisco-voice
vlan 100
authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip domain name site1.365873.trk.ipvoip.ch
ip name-server 8.8.8.8
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
isdn switch-type basic-net3
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
sip
registrar server expires max 3600 min 3600
localhost dns:site1.365873.trk.ipvoip.ch
no update-callerid
voice class codec 1
codec preference 1 g711alaw
voice register global
mode cme
source-address 10.1.1.1 port 5060
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
timezone 23
voice source-group CCA_SIP_SOURCE_GROUP_CUE_CME
access-list 2
translation-profile incoming SIP_Incoming
voice source-group CCA_SIP_SOURCE_GROUP_EXTERNAL
access-list 3
voice translation-rule 9
rule 1 /0041449475090/ /90/
rule 2 /0041449475091/ /91/
rule 3 /0041449475092/ /92/
rule 4 /0041449475093/ /93/
rule 5 /0041449475094/ /94/
rule 6 /0041449475095/ /95/
rule 7 /0041449475096/ /96/
rule 8 /0041449475097/ /97/
rule 9 /0041449475098/ /98/
rule 10 /0041449475099/ /99/
voice translation-rule 410
rule 1 /^0\(.*\)/ /\1/
rule 15 /^..$/ /0041449475090/
voice translation-rule 411
rule 1 /^0\(.*\)/ /ABCD0\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 422
rule 15 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
rule 1 /^9\([1-9]\)$/ /004144947509\1/
voice translation-rule 1112
rule 1 /^0/ //
voice translation-rule 2000
rule 1 /0041449475098/ /98/
voice translation-rule 2001
rule 1 /0041449475097/ /97/
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
voice translation-profile AA_Profile
translate called 2001
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Called_9
translate calling 3265
translate called 9
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile SIP_Passthrough_CallBlocking
translate called 422
voice translation-profile VM_Profile
translate called 2000
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
dspfarm
dsp services dspfarm
fax interface-type fax-mail
license udi pid UC540W-BRI-K9 sn FGL163220SL
archive
log config
logging enable
logging size 600
hidekeys
username admin privilege 15 secret xxx
username xxx password 0 ""
ip tftp source-interface Loopback0
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly in
interface FastEthernet0/0
description $FW_OUTSIDE$
no ip address
ip inspect SDM_LOW out
ip verify unicast reverse-path
load-interval 30
shutdown
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
no ip address
macro description cisco-desktop
spanning-tree portfast
interface FastEthernet0/1/1
switchport voice vlan 100
no ip address
macro description cisco-phone
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
no ip address
interface BRI0/1/0
no ip address
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
isdn static-tei 0
interface BRI0/1/1
no ip address
shutdown
isdn static-tei 0
interface Dot11Radio0/5/0
no ip address
ssid cisco-data
ssid cisco-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
antenna receive right
antenna transmit right
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Vlan1
no ip address
bridge-group 1
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip address 192.168.10.2 255.255.255.0
ip access-group 102 in
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.10.1
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 2 remark CCA_SIP_SOURCE_GROUP_ACL_INTERNAL
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 192.168.10.2
access-list 2 permit 10.1.10.0 0.0.0.3
access-list 2 permit 192.168.10.0 0.0.0.255
access-list 2 permit 10.1.1.0 0.0.0.255
access-list 3 remark CCA_SIP_SOURCE_GROUP_ACL_EXTERNAL
access-list 3 remark SDM_ACL Category=1
access-list 3 permit 212.147.47.216
access-list 3 deny any
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 192.168.10.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny ip 10.1.1.0 0.0.0.255 any
access-list 101 deny ip 192.168.10.0 0.0.0.255 any
access-list 101 deny ip 192.168.1.0 0.0.0.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_6##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny ip 10.1.10.0 0.0.0.3 any
access-list 102 deny ip 10.1.1.0 0.0.0.255 any
access-list 102 deny ip 192.168.1.0 0.0.0.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_8##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny ip 10.1.10.0 0.0.0.3 any
access-list 103 deny ip 192.168.10.0 0.0.0.255 any
access-list 103 deny ip 192.168.1.0 0.0.0.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_14##
access-list 104 remark SDM_ACL Category=1
access-list 104 deny ip 10.1.10.0 0.0.0.3 any
access-list 104 deny ip 10.1.1.0 0.0.0.255 any
access-list 104 permit ip any any
access-list 104 permit udp host 8.8.8.8 eq domain any
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny ip 10.0.0.0 0.255.255.255 any
access-list 104 deny ip 172.16.0.0 0.15.255.255 any
access-list 104 deny ip 192.168.0.0 0.0.255.255 any
access-list 104 deny ip 127.0.0.0 0.255.255.255 any
access-list 104 deny ip host 255.255.255.255 any
access-list 104 deny ip host 0.0.0.0 any
access-list 104 deny ip any any
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
cptone CH
station-id name FAX
station-id number 99
caller-id enable
voice-port 0/0/1
cptone CH
shutdown
caller-id enable
voice-port 0/0/2
cptone CH
shutdown
caller-id enable
voice-port 0/0/3
cptone CH
shutdown
caller-id enable
voice-port 0/1/0
compand-type a-law
cptone CH
bearer-cap Speech
voice-port 0/1/1
compand-type a-law
cptone CH
bearer-cap Speech
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 2 register mtpa4934c6ee4e0
dspfarm profile 2 transcode
description CCA transcoding for SIP Trunk VTX
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 10
associate application SCCP
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 99
port 0/0/0
no sip-register
dial-peer voice 2 pots
port 0/0/1
no sip-register
dial-peer voice 3 pots
port 0/0/2
no sip-register
dial-peer voice 4 pots
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description tcatch all dial peer for BRI/PRIv
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
direct-inward-dial
port 0/1/0
dial-peer voice 51 pots
direct-inward-dial
port 0/1/1
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 98
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 97
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 96
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk (VTX) **
session target sip-server
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
fax rate 14400
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1001 voip
corlist outgoing call-local
description ** star code to SIP trunk (VTX) **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
fax rate 14400
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls for PSTN from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound Calls for MWI from CUE **
b2bua
incoming called-number A80T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1009 voip
description ** Passthrough Inbound Calls for Internal Extensions from CUE **
b2bua
incoming called-number ^..$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1033 voip
description **CCA*Switzerland*Short Code Services**
translation-profile outgoing PSTN_Outgoing
preference 1
destination-pattern 0187
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1042 voip
corlist outgoing call-emergency
description **CCA*Switzerland*Ambulance / Poisioning**
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 1
destination-pattern 0014[45]
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1041 voip
description **CCA*Switzerland*REGA Air Rescue**
preference 1
destination-pattern 00333333333
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1025 voip
corlist outgoing call-national
description **CCA*Switzerland*National Destination Numbers**
preference 1
destination-pattern 00[789]1.......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1020 voip
description **CCA*Switzerland*Regional Announcement VM**
preference 1
destination-pattern 01600
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1040 voip
preference 1
destination-pattern 000333333333
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1043 voip
preference 1
destination-pattern 014[45]
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1035 voip
description **CCA*Switzerland*Mobile Numbers**
preference 1
destination-pattern 007[46789].......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1024 voip
corlist outgoing call-national-plus
description **CCA*Switzerland*Personal Numbering**
preference 1
destination-pattern 00878......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1029 voip
description **CCA*Switzerland*Voicemail Access**
preference 1
destination-pattern 00860.........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1036 voip
description **CCA*Switzerland*VPN Access**
preference 1
destination-pattern 00869.............
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1027 voip
description **CCA*Switzerland*Premium Rate (Business)**
preference 1
destination-pattern 00900......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1026 voip
description **CCA*Switzerland*Test Numbers**
preference 1
destination-pattern 00868T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1034 voip
description **CCA*Switzerland*Shared Cost numbers**
preference 1
destination-pattern 0084[0248]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1038 voip
description **CCA*Switzerland*Emergency**
preference 1
destination-pattern 0011[278]
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1037 voip
corlist outgoing call-toll-free
description **CCA*Switzerland*Toll Free Numbers**
preference 1
destination-pattern 00800......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1039 voip
preference 1
destination-pattern 011[278]
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1032 voip
preference 1
destination-pattern 00[23456]........
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1023 voip
corlist outgoing call-international
description **CCA*Switzerland*International Calls**
preference 1
destination-pattern 000T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1031 voip
description **CCA*Switzerland*Premium Rate (Social)**
preference 1
destination-pattern 0090[16]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1030 voip
description **CCA*Switzerland*Short Code**
preference 1
destination-pattern 014[0357]
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1045 voip
description **CCA*Switzerland*REGA/Glaciers Air Rescue**
preference 1
destination-pattern 0141[45]
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1028 voip
description **CCA*Switzerland*Directory Enquiries**
preference 1
destination-pattern 018[15].
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1021 voip
preference 1
destination-pattern 011[45].
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1022 voip
preference 1
destination-pattern 01[67].
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1044 voip
preference 1
destination-pattern 00141[45]
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 2002 voip
description ** cue voicemail PSTN number **
translation-profile outgoing VM_Profile
destination-pattern xxx$
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2003 voip
description ** cue auto attendant PSTN number **
translation-profile outgoing AA_Profile
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1110 pots
preference 9
port 0/0/0
no sip-register
dial-peer voice 3006 voip
description SIP
translation-profile incoming SIP_Called_9
incoming called-number xxx.
voice-class codec 1
dtmf-relay rtp-nte
no vad
no dial-peer outbound status-check pots
sip-ua
keepalive target dns:site1.365873.trk.ipvoip.ch
authentication username xxx password 7 xxx
no remote-party-id
retry invite 2
retry register 10
timers connect 100
timers keepalive active 100
registrar dns:site1.365873.trk.ipvoip.ch expires 3600
sip-server dns:site1.365873.trk.ipvoip.ch
host-registrar
telephony-service
sdspfarm units 5
sdspfarm transcode sessions 10
sdspfarm tag 2 mtpa4934c6ee4e0
video
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service phone ehookEnable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message SwissT.Net
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
user-locale U4 load CME-locale-de_DE-German-8.1.2.2.tar
network-locale U4
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-5-4
load 501G spa50x-30x-7-5-2b
load 502G spa50x-30x-7-5-2b
load 504G spa50x-30x-7-5-2b
load 508G spa50x-30x-7-5-2b
load 509G spa50x-30x-7-5-2b
load 525G2 spa525g-7-5-4
load 301 spa50x-30x-7-5-2b
load 303 spa50x-30x-7-5-2b
time-zone 23
time-format 24
date-format dd-mm-yy
keepalive 30 auxiliary 4
voicemail 98
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 xxx
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
transfer-pattern 0.T
transfer-pattern 6.. blind
secondary-dialtone 0
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 1
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
service phone webAccess 0
softkeys remote-in-use Newcall
softkeys idle Redial Pickup Mobility Newcall Cfwdall Gpickup Dnd Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer Mobility TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template 15
softkeys idle Redial Newcall Mobility Cfwdall Pickup Gpickup Dnd Login
softkeys connected Hold Endcall Mobility Trnsfer TrnsfVM Confrn Acct Park
ephone-template 16
ephone-template 17
softkeys remote-in-use CBarge Newcall
ephone-template 18
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn 292
number xxx
description SIP Main Number registration
preference 10
ephone-dn 293 dual-line
number 90 secondary xxx no-reg both
label Zentrale
description 90
name Zentrale
call-forward busy 98
call-forward noan 98 timeout 20
ephone-dn 294 dual-line
number 94 secondary xxx no-reg both
label LL
description Lehrling Lehrnende
name Lehrling Lehrnende
mobility
snr xxx delay 1 timeout 30 cfwd-noan 98
snr ring-stop
ephone-dn 295 dual-line
number 93 secondary xxx no-reg both
label CM
description
name
snr ring-stop
call-forward noan 98 timeout 10
ephone-dn 296 dual-line
number 92 secondary xxx no-reg both
label EE
description
name
mobility
ephone-dn 297 dual-line
number 91 secondary xxx no-reg both
label RS
description
name
mobility
snr ring-stop
ephone-dn 298
number 6.. no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 98
ephone-dn 299
number A801.. no-reg primary
mwi off
ephone-dn 300
number A800.. no-reg primary
mwi on
ephone 1
device-security-mode none
mac-address A44C.11A0.B648
ephone-template 1
max-calls-per-button 2
username "xxx" password xxx
type 525G2
button 1:296 2:293 3m297 4m295
button 5m294
ephone 2
mac-address A44C.11A0.B566
ephone-template 1
type 525G2
button 1:297 2:293 3m296 4m295
button 5m294
ephone 3
mac-address A44C.11A0.B5C4
ephone-template 1
type 525G2
button 1:295 2:293 3m297 4m296
button 5m294
ephone 4
mac-address A44C.11A0.B67A
ephone-template 1
type 525G2
button 1:294 2:293 3m297 4m296
button 5m295
alias exec cca_voice_mode PBX
alias exec cca_vm_notification schedule from_time=00 to_time=24
alias exec clid-ALL_BRI ;1:0-4;1:0-9;1:0-9;1:1-9
alias exec clid-SIP ;1:1-9;1:1-9;1:1-9
banner login ^CCisco Configuration Assistant. Version: 3.2 (3). Fri Jul 04 13:18:33 CEST 2014^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
ntp server 91.240.0.5 prefer
en
07-08-2014 03:14 AM
Any idea ?
Thanks guys.
07-13-2014 11:47 AM
Hi Patrick
I am working on this one as well. I have a UC560 with SIP Trunk provider Les.NET.
It was working fine until a few weeks ago when something changed on the provider end and broke it. My hunch it is something to do with the SIP REFER.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/91535-cme-sip-trunking-config.html
Here is an excerpt from the above page:
When a call comes in on an SIP trunk to an SCCP Phone or CUE AutoAttendant (AA) and is transferred, the CME by default will send a SIP REFER message to the SP proxy. Most SP Proxy Servers do not support the REFER method. This needs to be configured in order to force the CME to hairpin the call:
Router(config)#voice service voip
Router(conf-voi-serv)#no supplementary-service sip refer
Figure 3 shows the behavior of the CME system with the REFER method disabled.
07-16-2014 05:31 AM
Hi.
Just for information Call Transfer works, but not SNR.
But anyway, the Cisco TAC Engineer told me that the SIP Provider should support Hairpin calls, and he doesn't.
Patrick
07-16-2014 06:58 AM
