Smart Callconnector Operator and Server
steenbroberg
Hi Community
We need a solution with 3 x Smart Callconnector Operator and therefor need a server solution. As i can see the server Smart callconnector server software is not avaible for download. Is that right???
The SKU is released for ordering:  L-SW-SCC-SERVER
Is Smart Callconnector/Operator supported on the ISR router??
6 Replies 6
Alberto Montilla
Dear Sir;
The SCC Server (L-SW-SCC-SERVER) will be available for purchase from September 30th (tomorrow). Currently, it works with UC500 only.
Regards;
Alberto
Hi Alberto
Great!!
Is Smart callconnector Operator supported on unified callconnector server SW-UCC-SERVER, so that is possible to use Smart callconnector in a ISR router CME???
Dear Sir;
Current answer is not. The Smart CallConnector Suite is currently supported under UC500 platforms only. We are evaluating its support on CME-ISRs but it is not committed yet. Stay tuned for further updates.
Alberto
Is this the replacement for UCC Server and Client, I currently am running 1.6.x?  I have a smartnet agreement with the UCC server/Client so is this what I move to?
Dear Sir;
SCC is a different product line, so there is no migration option from UCC to SCC.
Alberto
I have version 1.6.x installed when I go to download ver 2. all I see is the Advanced client for 32bit and 64bit  I should be entitled to the version 2 so where do I go to get the server side.
