06-25-2011 07:29 AM - edited 03-21-2019 04:16 AM
I need to be able to turn off and on SNR right from the phone but it looks like it only allows to change the number. Is it possible to enable/disable right from the phone? Seems odd it's not there.
06-25-2011 07:37 AM
Hit the softkey "mobility" and press select to disable it or enable it. If you don't see the mobility softkey it could actually be a bug (CSCTN00437). There is a conflict with the locale and the ephone. When the locale is changed to US instead of U5, the template should come up correctly. Call small business support and this should be a quick fix for you if that's the issue.
06-27-2011 12:31 AM
You have to make a ephone-template and put the mobility softkey in it. After that is done it will shop up in the phone display (you need to apply the ephone-template on the phones and restart).
Here is and example:
ephone-template 1
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd Login Mobility
softkeys seized Redial Endcall Cfwdall Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer Confrn Acct Park Mobility
type 7940
ephone 1
ephone-template 1
06-27-2011 02:07 AM
These templates are actually already built-in by CCA and CCA will apply the correct template according to the features enabled. The bug I mentioned above can cause an issue where if any template is used, the softkeys will not show up properly.
