12-09-2009 09:55 AM - edited 03-21-2019 01:53 AM
is it possible to create a softkey to tranfer a call to a particular extension ?
thanks
hasratraj
12-09-2009 10:10 AM
The available softkeys for transfer are regular transfer and transfer to voicemail. You can configure monitor keys on the line buttons of the phone, and that allows direct transfer to the specified extensions, among other things. You could also configure speed dials and map them to an available line button, and then easily transfer to that number by pressing transfer and then such button.
Marcos
12-09-2009 10:58 AM
Hi Marcos,
is there a config or document for call transfer ?
hasratraj
12-09-2009 04:13 PM
Dear hasratraj,
CCA2.2 will let you setup a Monitor Button on a Phone Button.
You can also use trough this with the Unified Communications 500 Series - Administration website (10.1.10.1 by default).
Play arroung with it till you get the result you want.
