552
Highlighted
Beginner
Softphone as teleworker on UC540 easiest/cheapest?
The VPN client built into the SPA525G2 does a great connecting to the remote UC540.  But the user would like to use a softphone on a notebook for travel purposes.
Cisco has IP Communicator.  If someone purchased a UC540, do they also have to purchase licenses for the IP Communicator?  Any idea what the costs would be for basically a single user?
Also, does it have a built-in VPN client?  Or do I have to first establish a VPN connection, and then start the CIPC?  Can I use the VPN client that I installed into the UC540 when I was configuring it?
Are there any other softphones that will work with a UC540?  Bonus points if there are any that have a built-in VPN client.  I'd like to make it as simple as possible for the guy, he can be technology challenged.
Any tips on the fastest/easiest/least expensive path are welcome.
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
You will need to buy a license, and you will need either CiscoVPN client, or VPN Anyconnect. Cisco does not make sofphhones with a built in VPN.
For prices you can check with your reseller or browse online.
3 REPLIES 3
Highlighted
Hall of Fame Master
Highlighted
Thanks, at least I know what has to happen now.
Highlighted
Thank yuo for the nice rating and good luck!
