Softphone with SPA9000
alexpina2
Has anyone tested, any type of phone with the SPA9000?
Managed to register the same for the softphone to receive and make calls?
Thanks everyone
dsommerh
Hi Alexpina
You can use http://www.phonerlite.de/
There is a german and an english and a german free softphone which works very well with the SPA9000
for Registration of the phone to the SPA9000 you have to type in the following:
Proxy registrar: yourIPAdressofSPA9000:6060
Username is the number you wish to have
Should run immediately than.
Cheers
Daniel
CTRLITINC
Alex,
We have developed a call manager called Call Ctrl and was designed specifically for the SPA9000 IP PBX and the SPA900 and SPA500 Series IP Phones.
Although not technically a SoftPhone, it functions nearly identically as a softphone, but requires an actual SPA IP Phone. It allows you to dial and control your phone from your Windows Desktop.
We may add a SoftPhone to Call Ctrl at some point. Aside from this you can use any SIP compliant SoftPhone. We have used SipCommunicator (open source Java) and Sipek (open source .NET).
If you want to check out Call Ctrl you can look here:
www.uctrlit.com/CallCtrl
HTH,
Steve Wofford
Call Ctrl Call Manager for
SPA900 - SPA500 IP Phones
