08-23-2012 02:47 PM - edited 03-21-2019 06:12 AM
I have 7.4.9c firmware
When I do the call forward button and set it to a number the screen displays calls forwarded
When I call my line I get a message in my syslog server
calling:<forwarded to number>@<proxy>:0
I do not see any sip messaging back at my switch. I get the same results if I use an extension, on switch number, or cell phone
When I do a call forward of my 7960 the call goes to the correct number.
08-24-2012 09:14 AM
Sage,
Did you add the steering digit in the call forward field?
i.e. 9 for outside line steering digit must be appended to the number to be call forwarded to.
The 7960 might append this automatically.
Randy
08-24-2012 09:18 AM
I put in the number exactly as I would dial it from the phone so 17143388807
Once I hit the last digit the phone goes to Calls Forwarded on the screen
08-24-2012 09:33 AM
Then inbound call to the phone should generate a refer message to the call forwarded number.
Can you obtain a wireshark showing the call flow?
Randy
08-29-2012 03:46 PM
The spa303 is sending back a 487 Buisy message
