03-02-2011 12:39 PM - edited 03-21-2019 03:45 AM
We just switched our phones over to SPA 303's and we find that the Headset jack does not seat the 2.5 mm plugs properly from our plantronics headsets. Though we get some sound in...it is erratic....and we get no voice out. Anyone have any ideas? Thank you.
Solved! Go to Solution.
03-02-2011 02:16 PM
Hi David,
Just curious if you are using this "special" cable 2.5 mm to QD -PART NUMBER 48586-03.
https://supportforums.cisco.com/docs/DOC-9926/
Cheers!
Rob
03-02-2011 02:16 PM
Hi David,
Cheers!
Rob
03-02-2011 02:38 PM
Rob
That's a winner. Thank you. A special plug is needed and goes into place firmly when installed. Thank you.
