On a Phone (the SPA 303) of the SPA 5xx / 3xx family i have to turn off the The LED's for those Linekeys that are used as Direct Dial keys. But how?
On the used Linekeys (Linekey 1) it works perfect (well i am Provisionion, but the Web Interface is more or less the same ...) with
<Idle_LED>c=o</Idle_LED>
but on the 2 other Linebuttons, i use with:
<Extension_2_ ua="rw">Disabled</Extension_2_>
<Short_Name_2_ ua="rw">Handy xxx</Short_Name_2_>
<Extended_Function_2_ ua="rw">fnc=sd;ext=xxxxxxxxx@$PROXY;nme=Handy xxx</Extended_Function_2_>
<Extension_3_ ua="rw">Disabled</Extension_3_>
<Short_Name_3_ ua="rw">Intern Alles</Short_Name_3_>
<Extended_Function_3_ ua="rw">fnc=sd;ext=99@$PROXY;nme=Intern</Extended_Function_3_>
i find no way to turn off the green LED's... The Direct Dial Keys work perfect, just the green LED ist to bright for the clients sleeping room...
