Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
387
Spravce IT BCB
Beginner
SPA 30x and 50x - show miss state when call was pickup
Hello
Do you know how to setup SPA 30x or SPA 50x to show miss state (softkey) when call was pickup in pickup group, or was transfered to mobility extensions?
The old SPA 922 is showing very well.
Server is Asteriks.
Thank you
Marek
1 ACCEPTED SOLUTION
Dan Lukes
Advocate
Call completed elsewhere has not been missed, so SPA922 is on the wrong side ...
If the line is declared as shared AND call is CANCELed with
Reason: SIP;cause=200;text="Call completed elsewhere"
then no missed call is logged.
I'm not sure if you can configure Asterisk not to use this Reason in such particular case. If I remember correctly, there is and option of Dial() Application for it ...
Of course, unless you have User->Supplementary Services->Log Missed Calls for extension in question set to "Yes" no missed calls are logged at all.
Rate useful advices and/or mark answer as "correct". It will help others to found solutions.
2 REPLIES 2
Dan Lukes
Advocate
You have right Dan, I can not configure Asterisk, I thought when SPA 922 working well, maybe is possible to setup new SPA similar.
Thanks for reply.
