08-11-2011 02:26 AM - edited 03-21-2019 04:30 AM
can you pls tell me where can I find slovak localization for SPA 50X IP Phone series if possible ?
According to this website
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10499/qa_c67-552214.html
it should exist, but according to what I have read here, it looks that it doesn't exist.
In case that it doesn't exist, can you pls tell me if you plan to release it someday ?
Thanks in advance.
Best regards Eva
08-22-2011 04:50 AM
I have made slovak translation on my own recently, so if you want, you can use it.
http://zssmzh.edu.sk/VoIP/prov/cisco/lang/sk.xml
But I recommend that you use a narrow softkey label font with this translation.
It is tested with SPA303G2 and SPA502G and 7.4.8a firmware.
Lukáš Čamaj
08-23-2011 12:37 AM
Thank you,
looks usefull !
Regards Eva
08-24-2011 11:14 AM
Hi Lukáš,
Thanks for sharing with the community.
I've included your link to the https://supportforums.cisco.com/docs/DOC-9923 document.
Please let me know if you'd prefer me to add your document to the Community instead of pointing to your server.
Patrick
08-26-2011 10:53 AM
you can add translation to comunity page instead of linking to our server.
If I make some updates to translation, I will send it to you.
Lukáš Čamaj
On 24 August 2011 20:14, paborn
