I am using Cisco SPA 525g, but when i apply DND from the terminal, it does not sync with the Broad Soft.
I am using firmware: 7-5-3.
Any idea, how to sync the DND with Broadsoft, when applied from terminal.
Shivam
Hi Shivam,
Have you already enabled the following parameters under 'SIP' when youre logged on as admin :
'Hold Package'
'Talk Package'
'Conference Package'
You might also need to delete all the entrys at 'Vertical Service Activation Codes' under 'Regional'.
Joëll
Hi Joell,
Yes other packages has already been active.
Cisco 504G is working fine. The only issue is with 525G.
Shivam
